Hey guys! Just a quick question.
After my last stage of installments my r33 gtst is now running over 220rwkw, however im having all sorts of trouble putting that power to the ground and before I go for any more power i think it needs to be addressed.
What suspension/handling upgrades are there out there that I should be looking at for my rb25?
I know a good set of tires is an obvious reason and also a reduction in tire pressure also helps but what other ways are there so I can keep it in a straight line? At the moment under full throttle and it cannot hold grip until the beginning of third :/
Cheers!!
https://www.sau.com.au/forums/topic/373754-traction/
After some quick research I have compiled a list of things that would help address this issue and improve overall suspension. What do you guys think? Have I missed anything?
Decent tires (Kuhmo Ku36 for street use)
Front and Rear Coilovers (monovalve)
Castor rods
Front & Rear Camber arms
Adj Tie rod ends
Pineapples
Nolathane Control upper arm inner bushes
Nolathane radius rod adj bushes
https://www.sau.com.au/forums/topic/373754-traction/#findComment-5962711
Half that list won't actually do anything for straight line traction.
On stock suspension you really should not be having traction issues if you have good tyres and a good alignment. Do those first before doing the rest.
https://www.sau.com.au/forums/topic/373754-traction/#findComment-5962926
As said above what you listed will help grip or drift where corners are involvrd straightline traction almost goes oposite with softer suspension zettings working better. The adj arms are only used to correct or customise alighnment settings wben you change the geometry for example lowering it.
So just get the tyres and you should find that solves your problem espcially at 220 kw
https://www.sau.com.au/forums/topic/373754-traction/#findComment-5963004
ahhh!
i am also having the same problem, just found this post while browsing so i havnt done any research yet,
but im also quite confused as my rb25 is still stock just running actuator pressure (nothing over 9psi)
i can take off smoothly (ie. im not dunping the clutch) and as soon as i get the pedel to the floor the ass jumps around like a mofo, if i grab 2nd quickly it keeps spinning the tires till i grab 3rd
as far as i know all my suspension is stock, but the guy i bought it off did say that it was really low when he got it.
ill check the springs tomoro n hope it wasnt a chop job too :S
thanks for the advice ^^^^^ i now have a list to run through :D
https://www.sau.com.au/forums/topic/373754-traction/#findComment-5964052
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
