  • Replies 91
I got a twin plate exedy put in last weekend, with a new thrust bearing from nissan...
Its been perfect all week... the pedal is heavier and the engage point was only just up off the floor (how a new clutch should be?)
Last night something must of happened because the engage point is now all of a sudden all the way out (like my old clutch was just before it died)...
any ideas what this would be?
is there much involved in getting a Nissan patrol clutch into my R33?
Its it a bad or good idea?
What kind of parts are involved other than the clutch plate?
They are very heavy and thus slow down the response of the engine, kinda the reverse of a light flywheel.
You get a fricton plate, a pressure plate and a thrust race in the kit.
Hope that helps :)
thanks Sydneykid for clearing some up....
so, rattle is normal...even though its so loud normal ppl thinks ur car is stuffed :(
pivot ball hasnt broken - i've whitnessed my other bros gtst when that happened...
Emre - yep its a secondhand orc twinplate... very new though 3.9mm plates...
i have tried bleeding it again.....this time taking out the dampener system as well
like my 180.....to bleed the slave cylinder it needs to be pushing against something right?
ie. clutch fork > pressure plate.....i found that it wasnt going anywhere until i physically
pushed the fork against the S.cylinder then it started to pick up...
i dont think anything is broken......at the start i thought that i might have machined
a bit too much off the carrier too but why would it work fine during the 500ks?
which leads me to believe that somehow somethings moved, but how?
when bleeding i tried putting something between the fork and the S.cylinder tip and it
felt much better (pedal) but didnt wanna try starting car on the stands....
i will probably remove the dust boot and take a look inside..
  • 1 year later...
Hey Sk - old thread and all. I have a Patrol clutch in my car.. are they heavier than the equivalent skyline HD clutch (single plate)?
Seems to feel like a decent clutch but am I loosing out on a bit of response?
Not that I'm going to change it but wondering what power it is good to - around 230rwkw?? Its a bit over a year old - so pretty new still
Thanks
Edited by benl1981
Can anyone confirm for me if the series 2 r33 gtst has a pull type clutch or a push type clutch.
Steve,  where did ya get your twin plate os giken from?
i have a series two gts-t and it is push type
hey i have read a heap of these clutch threads and cant find a straight out answer. I need a clutch to hold around 280rwkw in an r33 series 2 box...
im assuming launching in a button in the wet up hill in traffic is impossible...so i am wanting to avoid that....what are my options?
Thanks for the advice in advance.
Old thread but I'll thow my 2 cents in :)
I've just installed an O.S.Giken TSR2CD Twin Plate Clutch and so far I'm impressed !! It has a MUCH lighter pedal feel than the old TS2C/D and TS2B/D. It has the same feel as a stock GT-R clutch ( which takes a lot of getting used to :P ). It's still rated to 600hp at the engine and is very driveable. The new clutch kit comes with a new release bearing and carrier already assembled. Cost is around the $2k mark but is SO worth it when you next get caught in traffic :P
BTW If anyone wants a really good 2nd hand O.S.Giken Twin Plate Clutch that will hold up to 250rwkw for R31, R32 or R33 at a great price, PM me :(
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
