1 piece split dump pipe (i believe its a jjr one) $150
post-27276-0-77103500-1313383632_thumb.jpg post-27276-0-78181600-1313383653_thumb.jpg
Blitz BOV, has an attachment (flange needs to be welded to the tube) to plumb it back if mounted in the factory position, DOSE NOT come with the adaptor to mount in the factory position $60
post-27276-0-92676600-1313383389_thumb.jpg post-27276-0-96208500-1313383417_thumb.jpg
6x factory gtr coils (Will also fit S1 R33 and R32), all worked well, i replaced them with yellow jackets when i put the 3540 on $120
post-27276-0-75948700-1313383503_thumb.jpg post-27276-0-69864300-1313383518_thumb.jpg
Crank angle sensor, bought it to try to fix a problem but the cas was not the problem $70
S1 igniter, once again bought to fix a problem, it wasnt the igniter either, i have 2 of these $90 each.
Standard front and rear struts with lowered rsr springs, no leaks worked well, replaced them with height adjustable coil overs when i got defected for too low (the only part of the car that was too low was a flange on the exhaust) $275
post-27276-0-94791400-1313383691_thumb.jpg post-27276-0-90965700-1313383707_thumb.jpg
S1 R33 grill with red S badge, replaced with GTR style grill but i didnt like the red badge so i swapped it for the factory chrome one, two clips missing of the back, just missing not broken, if this is to replace a damaged grill you could probably get a couple out of the one, how ever the center one is broken off, only ever had 3 or 4 of them on when it was on the car and was 100% secure without the middle one $30
post-27276-0-22794100-1313383447_thumb.jpg post-27276-0-82797200-1313383479_thumb.jpg
Factory gearbox speed sensor, came off a S1 R33 gtst no idea what other models it would fit, one again bought to fix a problem and that was not the problem $60
Battery box, no strap or brackets $30
S1 R33 indicators with built in driving/fog lights $40
post-27276-0-44095900-1313383302_thumb.jpg post-27276-0-13833300-1313383322_thumb.jpg
All prices are negotiable so throw me an offer, will also swap for an unmolested Mspec front bar and reo (happy to deal if you have either or both) for a S1 R33 gtst.
https://www.sau.com.au/forums/topic/374105-r33-parts/
how much you want for the front and rear shocks? Could you please sms me reply on 0404085915 thanks
Do you meen without the springs? if so im not willing to separate atm, price is up there for the lot or throw me an offer.
All pm's have been replied to.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5968262
Struts and Mspec lights sold, also have a HKS mushroom pod.
Comes as pictured, it did have a securing bracket but that seems to have gone missing, if i find it before it is sold i will include it other wise it does not come with it $60
post-27276-0-19229200-1313490990_thumb.jpg post-27276-0-15147200-1313491010_thumb.jpg
Everything else below is still available.
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5969955
Adding a S1 vented fibreglass bonnet:
Good condition, does not come with washer jets $200
post-27276-0-38573200-1313905951_thumb.jpg post-27276-0-73428000-1313906196_thumb.jpg
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5977235
Bonnet sold.
grill, hks pod and dump pipe sold pending payment.
Below is what is left.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5983285
Dump pipe, pod and grill back up for sale.
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5985994
CAS sold.
HKS mushroom pod, Comes as pictured, it did have a securing bracket but that seems to have gone missing, if i find it before it is sold i will include it other wise it does not come with it $60
https://www.sau.com.au/forums/topic/374105-r33-parts/#findComment-5986654
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
