Hey all the replacement RB20 i've installed in my girlfriends 32 gts-t is a dud and we're urgently chasing another..
The head is good so a good condition bottom end would probably do the job fine, this motor i bought from someone on here which apparently had 76ks on it has 50psi on 6th and 90 on 5th and have been quoted a big price for the full engine rebuild it needs!! So thinking its probably going to be a hell of a lot cheaper to find a 2nd hand motor in good condition this time!
I don't need turbo, loom, injectors, manifold, cams, coils or anything as the car currently has all that plus a spare lot of most things from the old one!!
Any help finding one would be greatly appreciated!!
Cheers, Tobbie
