Team,
The Alfa club of NSW are quite low on entries for the interclub sprint on 28th august.
Its $165.00 and it includes a timer.
you will need to be a memeber of a CAMS affiliated car club and also hold a Wakefield/AASA/CAMS L2S licence
If interested http://www.alfaclubnsw.org.au/events/index.html then you'll see aug 28th, then forms. click to download
please let the event secretary know also.
https://www.sau.com.au/forums/topic/374202-wakefield-supersprint/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
