hey guys, another exhaust thread..
I got a quote of 190 fitted for a 2.5" cat back system for my 33....
The thing is the guy told me they make it up there as you can't get system to just 'bolt-on'...is this BS?
Recomend me a moderetly priced system...mainly need it to sound sweet as stocko one sounds stupid :(
https://www.sau.com.au/forums/topic/37441-exhaust-yes-another-one/
well the stocko one sounds like gas hissing out of the tail pipes so its not much of a noise. There are Cat back systems, however the exhaust shop u went to probably don't get aany in as most are made in Japan. 190 for a catback is fairly cheap man, they will most likely be fitting a mass manufactured muffler such as a lukey or redback and just mild steel piping which probably won't be mandrel bend. If i were you i would do abit more shopping beofer getting one fitted. I had a lukey on my NA, cost $280, top of the linelukey muffler tho, and mandrel bent piping.
Clint
Clint
well in comparsion a 3" exhaust for a turbo charegd model is about $900 fitted
thats with 5" muffler or 4", size of muffler doesnt affect price. thats stanless steel and mandrel bent pipes from the turbo back
there are two type of bending from my knowledge. If I'm wrong about the following please feel free to correct:
Press bent - can be done by any exhaust shop. Causes pipe to become smaller in diameter where the bends are i.e --> ) (. Causes restriction in flow where the bends are.
Mandrel bent - requires more sophisticated bending machines. Pipe stays same diameter where the bends are i.e --> | |. Flow stays the same throughout the pipe.
HKS34R yeah ur descriptions are precise. Mandrel bending machines stretch the pipe pretty much to create a bend that is same diameter all the way through. Im pretty sure i had a Lukey Turbo Muffler which isn't straight through but flow's really well and just sounded great.
Clint
Remember you get what you pay for.
$190 is bugger all for an exhaust. You will probably get those nasty redback resonators that have protruding lumps that create a huge amount of backpressure/turbulence.
Ensure the mufflers/resonators they are fitting to the car have a smooth clean inside.. Hence the punched holes don't mave any material protruding in to where the exhaust gas flows.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
