Hey Guys,
I have a set of 19 x10.5 +21 offset Volk GTC's in diamond black, with 265/35/19 Pirelli P-Zero Rosso asymmetrical tyres $4000 or wanting swap for wheels of interest of the same size,these wheel are the perfect fit for the R32/33/34 GTR no guard rolling needed
wheels im looking for are:
Volk TE37 in black or bronze
Volk CE28n in black or gold
Nismo LM in black,white or Silver
As mentioned before looking to sell/swap in the Sydney as these wheel are located in Sydney's west pm me for more info or pics
im also open to other offers but they must be in the same condition preferably with tyres,cash adjustments considered if need be.
wheels on offer pictured on the silver R33 GTR
post-1164-0-28602100-1313590965_thumb.jpg post-1164-0-01942300-1313591076_thumb.jpg
Edited by Hiroshima Screamer
https://www.sau.com.au/forums/topic/374421-19-volk-gtcs-in-diamond-black/
  • 1 month later...
These are now on ebay at a bargin starting bid price of $3000 inc tyre!! , as im really needing the cash now.
http://www.ebay.com.au/itm/230688606034?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
these were up for sale by the previous owner and as you can see ,they are not cheap!
http://www.skylinesaustralia.com/forums/topic/332379-volk-gtcs/page__p__5574312__fromsearch__1#entry5574312
my loss your gain so get in quick and grab a bargin.
alot of interest in the wheels but so far no cash , back up on ebay new starting bid
willing to swap for other wheels 18" as per my above list with slick tyres or single Turbo kits eg TO4z or bigger for rb26.
I have t78 kit if you interested in swap ?
Ive put the wheels back up on ebay if there's no bids by Sun night ill swap you for the kit , if my wheels sell ill just buy the kit outright.
could you send me some more pics back of the turbo ect, is there anything else id need to bolt up, how come you have decided to sell the kit noticed you only just bought it not long ago?
Mate if they would fit my car I'd buy them in an instant but 10.5 is just too wide. It makes me sad to see these rims unwanted.
Thanks mate yeah its very hard for people to cater for such an aggresive stance but RH9GTR R32 im sure has the same wheels and made it work, will be puting up some pics tommorow,looks tuff az!
Bought it as impulse buy and decided to stay twins and want to get -5s now so just sitting here , i can orange to meet you so you can look at it in person if you like ? Ok if you dont want want swap as i am buying some 19te37sl now but im still keen if you want , cheers Aaron . (i will put some more pics on my for sale thread)
When are you be able to meet up i can bring a pair of wheels so you can have a look also , are you available this weekend? pm me.
in the mean time here some more motivation , nothing like a set of these wheels to complete a R32 GTR :worship:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
