RB25 Gearbox with short shifter low k's $1300 firm
Bonnet hinges $50
Drivers side door complete white $125
Dashboard $75
Rear seats $50
Air flow meter pionk label type no plug $100
17" wheels $500 with nearly new tyres and locknuts included
Rear subframe $200
CV shafts $75 each
Torsen diff $150 with side flanges
Rear brake set up $350
Side rear quarter windows $100 each
Rear wiper motor $40
Front wiper motor $50
Power steering rack $150 including tie rod ends in good condition.
All seats belts $50 per corner
ABS unit $50
Roof lining no marks really clean $40
May also have other little parts but not much more left.
Located in Windsor NSW but can post small items at your cost.
All reasonable offers considered.
Tim
0404321205
Pics upon request, text me and ill text you a photo back.
https://www.sau.com.au/forums/topic/374537-left-over-r34-parts/
I have been told it is a torsen out of an S15 and i have no problem with opening it up at all, text me and ill open it up and text you back with a pic.
Tim
Do you KNOW that it's a Torsen diff? If it is, I would like it. If you don't know for absolute sure, I would appreciate it if you would open it up and look/take photos of the centre.
cheers
Edited by Wilkins026
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
