Sundays? Maybe im getting Calder and Winton confused. Sundays would be great.
Cant make it anywhere tonight as im relying on leg power to get about until i drive my car down over Easter Break.
Thanks for the offer, ill take a rain check if thats ok. You say Sam =, is that Dr Drift, i need to talk to him about some work on my car after Easter
Jamezilla... are you the same James i met at the NDSOC meeting the other week? (i was the blonde fella boring Goeff to death).
Roy, Yes it was that James along we me (Andrew) and R31Nismoid (Ash) that were at the NDSOC meeting a few weeks back. :wavey:
All of us will be at MAS this weekend so you will have no problems finding us. And there will be a big cruise a couple of weeks after Easter so you can get decent fix then.
lol yeah I am... been very disorganised lately... had my mate in a car crash tuesday nite, so it sorta messed me up a bit...
ahhh jarrod... kewll... i'll be buggin ya more in the near future :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
