Hey all,
Well over the weekend I did an oil change on my car. I put some oil flush in and run the car for about 15 minutes and then drained the oil from the sump (black as hell)...after about 20 minutes to let it drain completely put the bolt back in the sump and went to take off the oil filter from the relocator.
When I took off the filter, oil spilled out of the filter and down the LHS (when you standing in front of the engine)...causing oil to spill on to the floor. So I cleaned the oil on the floor and tried to clean up around the LHS of the engine as much as I can. Once I did that, put the new filter on and poured in my new oil (GW Syn-X 3000). Now after I checked everything and went for a drive to the shops. The next morning I can see a pool of oil that's leaked onto the concrete...I touched and it looks like the old oil is dripping from underneath the car somewhere...I cleaned up most of it with a rag over night and checked this morning and there is no drips but when I drove to my client this afternoon, I decided to have a look when I went out for a ciggy and saw oil drops on the road...
what's the best way to clean all that up...I'm assuming that I might have to jack the car up and attack it with some degreaser or something else from underneath the car (I have big hands and arms to attack from the top)
It's slowing driving me mad with oil dropping (I'm only hoping it's old oil, if it's new, fresh oil...then I'm screwed because I don't know where it's exactly coming from)
Thanks In Advance!!
Edited by BigDirtyJase
https://www.sau.com.au/forums/topic/374972-best-way-to-clean-up-oil-leak/
if its black old looking oil, dont stress. if its honey coloured, then worry where its coming from
hit it with some degreaser, same with the concrete floor.
just keep it away from any electricals and the fan belts.
Well I degreased the car around the relocator kit and now I know I have an oil leak :-( ...looks like it's coming from one or both of the braided lines from the relocator (where the oil filter screws on to). I have been checking my oil and it's all ok for now
Now my guess is I need to replace the hose or hoses (this is going to be fun)....does anyone know the size of the hoses....I might just get regular hoses for the time being.
Hey Jason, just in case you haven't pinned down your oil leak yet...........your oil relocator fittings be tapered, nip 'em up. And before you go changing hoses I would check to see that I did not have prob with filter/seal changeout. Sometimes old oil seal can stick in place, not noticed. Double "O" rings (new over old) leak like a sieve, as does damaged/malformed/nicked/misaligned new seal.
Just a thought.
Cheers GW
Just a thought.
Cheers GW
I checked the around the filter...it's no leaking from there...it's definitely coming from the hoses (I'm going to hate taking them off...because one side has the crap Earl's clamp fittings, it's going to take some time to get them off...and blood will be drawn and lots of swearing
personally i think degreaser cans are a waste of money, buy a can or 2 of brake cleaner and give the area around the oil filter and where you spilt a hit and also on top of the diff (if its an RS4) maybe dont do this in your driveway though
They both do the job but brake cleaner is a little bit more effective....I just happened to have like 4 and half cans of degreaser in the shed...might as well use them (there is alot of oil stains on the driveway from multiple cars with oil/power steering leaks over the years)...
anyways...Where is the best place in Melbourne where I can get either braided lines and either the crappy Earls clamp type ends or proper AN -10 fittings (would that mean I have to change the fittings on the relo kit)...or where can I get good rubber hose from?
Rubber hose whilst cheaper...will keep me going for now (waiting to get paid from work...god I hate montly pay sometimes) but want to go with proper braided lines and fittings down the line
stuff knows whats in it but its alcohol based and breaks down grease and grime like nothing else and evapourates. most degreasers are soapy/slimey crap in a can that leave a residue. its so cheap cos its mainly water and people see 'degreaser' and think thats what im looking for
i dont think we have a can of degreaser in our whole workshop, apart from the 44 we have full of orange scented degreaser with cut down and use as floor cleaner
UPDATE,
I took my car to my friends shop today to check out this oil leak because it's gotten progressively worse...checked the lines and found that they were actually OK. Found that it was leaking from the oil temp sensor hole (it had an adapter so I could fit the sensor)
So I cleaned it up and resealed it, only to find it leaking again, tried another fitting and still leaking. Ended up having to take off the entire relocation kit and put the oil filter back on the block.
I need to clean up the re-locator kit and need to see it why it was leaking. My mate thinks that the fitting hole on the filter block is cracked but can't tell without cleaning out the old oil.
I wonder where I could get another filter block (if my one is cracked and can't be repaired) from or I might end up going with just a sandwich plate
Once I clean it up, I'll post some pics of the filter block
  • Like 1
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
