I removed my RB26 head off of my BNR32 while the motor is still in the car and I was wondering what I can do without while I still have everything accessible. I read somewhere that an RB20 oil filter housing can be used to eliminate the water lines going to the RB26 oil filter housing. What about the water lines running to under the intake manifold?
I am not looking to "shave" my engine bay or anything, just trying to simplify things under the hood and have less things to go wrong.
Thanks,
https://www.sau.com.au/forums/topic/375345-things-to-omit-on-rb26/
Are you going to substitute the original oil cooler with a front mount oil cooler? If not, then why the hell would you want to remove it. If I were building any other RB that didn't have the water cooled oil cooler of the later 25s and the 26s, I would be looking to add one as a minimum, and to hell with the extra water lines. They're a price I'd be willing to pay. And why mess about with trying to delete water lines under the inlet manifold? Just replace them with new ones and be happy for another 10 years or more.
hey, i'm in the situation as you. i chose to do the following for my track car build:
-painted the valve covers, intake plenum, and other things
-full hicas delete
-oil cooler ( i chose to leave the stock one in place, but deleted the water lines to it.)
-rear oil drain/breather
-lots of cleaning
Edited by black bnr32
It's actually more or less an oil warmer.
Which is a bad thing how? Warms cold oil up a little faster, which is better for the engine, and takes some heat out of the oil (and puts it in the radiator) when the oil is much hotter than the coolant. Just what the doctor ordered.
Edited by GTSBoy
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
