The official FD1 video is still with me.
There is about 1.5hrs of highlight footage.
I was out of the country for 4 weeks because of some honeymoon thingo.
Ive been trying to convert the damn thing to dvd with no sucess. I seem to be loosing way to much quality in the picture - and i was not happy with the final product.
Anyway im on to plan 69 and think i should be able to get it converted to dvd with practically no loss.
As soon as its done ill burn up the 30+ copies for the guys who attended the FD1.
Sorry for the delay.
Kero
https://www.sau.com.au/forums/topic/37540-drift-vid-update/#findComment-756021
The time has come good people. I have the final DVD's from FD1 (Fatz's Private drift Day - Oran Park 24/01/2004).
Participants of FD1 contact your local Fatz supplier for delivery of your complementary copy:)
(At the latest you can all get them from Fatz at FD2 on the 01/05/2004).
Sorry about the huge delay. Ive had to rely on a few favours from a few people to go through the steps of getting this to DVD. And i hate hassling people to get the job done faster when they are doing me a favour.
After not being happy with the quality of the video to dvd transfer i moved to plan 69. Its now on DVD with practically lossless image quality.
Its 1hour and 30 minutes of highlight footage from the day.
It is impressive to watch. Most people took the first few circuits nice and easy and by the end of the day (before the rain) everyone is carving it up.
If i had more time i would play around with the DVD menu but i figured who cares. So here it is.
Now i know what needs to be done i should be able to provide the FD2 DVD's soon after the event.
Cheers
Kero
PS. Go Britany
https://www.sau.com.au/forums/topic/37540-drift-vid-update/#findComment-792878
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
