Thinking about getting myself a scooter for work (will take the 125 test).
But has anyone had any recent experience with one ie are there any out there that can do 110kph or 120kph?
I have to go up a single lane highway @ 110 ish so dont want to be holding everybody up (thats if its even legal to go a highway on a scooter) as i am new to them, just thought i would throw the idea out there and see other peoples views...
if so what brands/makes are good??
I want somthing sporty looking :)
https://www.sau.com.au/forums/topic/375627-125cc-scootersmoped/
Most scooters should comfortably get along at 100-110.
The Yamaha Aerox 100 is a good one. I like 2 strokes. Although they tend to top out at about 100. That said, there are tons of aftermarket bit available to get them cranking harder like pipes, clutches, carbies, barrels and the like.
EDIT: https://www.pmtuning.co.uk/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=00219100AEROX
Edited by Cowboy1600
If you don't have your bike licence already you're only going to be able to do 80 anyway?
I've got a postie, that'll do 80 :P
If you've already got a licence then why the fudge are you getting a scooter so small?!
edit: I'd look at a Sachs Madass. They're awesome :D They'll do 110 easy assuming you're not too heavy whistling.gif
Edited by zoidbergmerc
This is like saying you want racing stripes on a getz.......
Im not sure what the rules are in WA but here in QLD you cant ride anything over 50cc without a Bike licence. I would suggest a cheap 250cc bike.I have a ninja 250r.
I would suggest a bike with a bit more capacity if you are going to be wanting to hold 100 to 110km esspecilly on hills. My 50cc jiajue scooter was not to slow for a 50 but up hills it suffered big time. (got it to 80km down a big hill once)
Yeah sporty looking as in not like a vespa or big wheeled postie bike!
Yeah looking around i will have to go 50cc unless i do a test...
At this stage its just an idea, but it means i have more to sepdn on the gtr :)
get your bike licence then get a 400cc registerable dirt bike. will easily do the speed limit without having to scream its tits off.
No LAMS in WA till next year, so that means 260cc max.
I used to race them in qld
Go the aerox and make it a 50cc one
The 50 is water cooled and also has the rear disc brake.
There is so much after market stuff for these its insane. You can get them up to 30 plus hp from 4hp
The aerox 100 is is only 8hp and will get kicked by a 70cc aerox.
I have built a few of these engines for race bikes now
Lol sounds good who can do that inw a and how much??
Went into honda (couldnt find yamaha dealers) they tried convincing me to take the 250cc test and buya 250cbr....
did i mention i have a crf250 in my games room looking for a home gerry...?
registered
sporty
will do 120 with current gearing but stock gearing did 150+
just hit 4000kms
electric and kickstart
just sayin :whistling:
bunbury yamaha is across the road from harvey norman near orbit fitness and paint shop :thumbsup:
You cant buy aerox,s anymore they stopped importing them in 2008 for some reason.
I do all my own porting and engine building , price depends on how fast you want to go . You can spend up to 10k on an engine if you want .
But if you put 1500 into an engine you will get a real tough street setup that will pop stands easily
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
