Hey guys yes VCT is turned off it was
Dropping off at hi rpm now it has another kick
He also said that the front pipe an pod are holding it back...
Peak power is more likely to be held back by your fuel system than your front pipe and pod. VCT can be turned off mid way through, so have it on until 5000rpm to boost your torque up to that point (you're definitely missing torque out down there), then turn it off to ensure that it maintains the same high rpm power you are currently seeing.
The reason it feels like a stout kick up high is before its lacking the torque the motor could be making up until 5000rpm, the engine is designed to rely on VCT to have a good spread of torque - you're potentially missing out on ~10% of the torque you COULD be making at 4000rpm, which you'd definitely know about.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5993328
Was it fully tuned with it both engaged and disengaged? Dynoing with VCT off in areas where the engine is tuned with it on - or vice-versa, means that the tune will be off for the current state which could give a misleading indication of where the curve intersection point should be in an ideal situation.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5993425
When you say fully tuned, do you mean an individual tune either way? The comparison was done on mine with only one tune, the current one. I lost 20rwhp in the middle from having it off. It made no difference above 3900 so that's where we left it.
Also, DVS JEZ mr nissan would have worked out the vct switching point based on a car running 5 to 7 psi through a stock turbo with an entirely stock car. Its possible that when a car gets everything on it swapped over from the computer to the tailpipe that it would have a different vct switching point.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5994661
Mr nissan would have spent alot of time working out the best VTC switching point
Probably, but when we are tuning non-factory setups with non-factory ECUs we don't have the luxury of using whatever rules Nissan implemented - nor can we be assured that they are calibrated to perfectly match whatever deviation we have from what they designed in the first place. We can't even be sure that they had our best interests (ie, powah!!) at heart, I know of other manufacturers definitely making decisions on this kind of thing based partly on how "exciting" it feels (often at odds to the outright best performing), emmissions, fuel consumption as well.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5994746
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
