Hey guys yes VCT is turned off it was
Dropping off at hi rpm now it has another kick
He also said that the front pipe an pod are holding it back...
Peak power is more likely to be held back by your fuel system than your front pipe and pod. VCT can be turned off mid way through, so have it on until 5000rpm to boost your torque up to that point (you're definitely missing torque out down there), then turn it off to ensure that it maintains the same high rpm power you are currently seeing.
The reason it feels like a stout kick up high is before its lacking the torque the motor could be making up until 5000rpm, the engine is designed to rely on VCT to have a good spread of torque - you're potentially missing out on ~10% of the torque you COULD be making at 4000rpm, which you'd definitely know about.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5993328
Was it fully tuned with it both engaged and disengaged? Dynoing with VCT off in areas where the engine is tuned with it on - or vice-versa, means that the tune will be off for the current state which could give a misleading indication of where the curve intersection point should be in an ideal situation.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5993425
When you say fully tuned, do you mean an individual tune either way? The comparison was done on mine with only one tune, the current one. I lost 20rwhp in the middle from having it off. It made no difference above 3900 so that's where we left it.
Also, DVS JEZ mr nissan would have worked out the vct switching point based on a car running 5 to 7 psi through a stock turbo with an entirely stock car. Its possible that when a car gets everything on it swapped over from the computer to the tailpipe that it would have a different vct switching point.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5994661
Mr nissan would have spent alot of time working out the best VTC switching point
Probably, but when we are tuning non-factory setups with non-factory ECUs we don't have the luxury of using whatever rules Nissan implemented - nor can we be assured that they are calibrated to perfectly match whatever deviation we have from what they designed in the first place. We can't even be sure that they had our best interests (ie, powah!!) at heart, I know of other manufacturers definitely making decisions on this kind of thing based partly on how "exciting" it feels (often at odds to the outright best performing), emmissions, fuel consumption as well.
https://www.sau.com.au/forums/topic/375658-yeww/page/2/#findComment-5994746
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
