Sumitomo or whatever it is is just what's printed on the standard gts-t calipers. Its what I have on my R33 and most I've seen.
I think some of the earlier r32 (and maybe some r33) have some brakes that are stamped with something else. I think they're pretty much the same though in terms of stopping force, etc.
https://www.sau.com.au/forums/topic/37570-r32-gts-t-brakes/#findComment-758721
Every R32 GTST with std brakes i have seen all have the same calipers you describe.
If the external appearance is smoother but still says Nissan on them then its possible he has R33 GTST calipers or R32 GTR calipers.
As for upgrading to R33 calipers i dont really see the point, rotors maybe but not caliper.
They have the same number of pistons and same piston diameters and still only accept the 30mm thick rotor. The R32 GTR brake caliper again is still 4-pot and has the same size piston diamter but can accept a 32mm thick rotor.
https://www.sau.com.au/forums/topic/37570-r32-gts-t-brakes/#findComment-766610
My R32 has the same brakes as urs too, its a 92 type m, brakes have heat sink things and sumitomo printed on them
A bit off topic but can you use r33 disks in an r32? I know they are slightly larger diameter, will they fit?
https://www.sau.com.au/forums/topic/37570-r32-gts-t-brakes/#findComment-767125
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
