  • Replies 46
Posted Images
Good to hear that this has worked well for you mate. Now time to dyno it to have a power figure to work with :P
Well, I got it dynoed a week ago, completely stock turbo 5psi, 134rwkw which is pretty basic for a stock rb25det (auto), i was told boost it to 10psi could get another 30rwkw maybe? will have to find out :)
good o hear :yes:
Hypothetically i get an increase of 30RWKW, that will make it 165RWKW, what would be the next best thing to do to this engine to make it say hit the 200RWKW mark and be safe for stock engine and running gear?
just after some informed opinions, the next best mod or change to get it to the 200 RWKW mark :)
high flow turbo or a garrett aftermarket turbo GT3071x
thanks, i was hoping there could be other mods without changing the turbo? or can you get a decent turbo for a few hundred and just straight swap? :) just after 200rwkw :P
If you haven't already:
  • 3" exhaust turbo-back exhaust
  • a front-mount intercooler
That with an ECU tune should see you around 200rwkw
Hell, my R34 was doing 182.7rwkw with just a 3" exhaust, and an intercooler - still on factory boost solenoid (saw peaks out to 8psi).
I've since fitted a 10psi R32 actuator; I would hope mine will do in-excess of 200rwkw once my ECU is tuned (I have an un-tuned nistune fitted)
Unfortunately in your case with an R33, a nistune is a less straight forward exercise, but an ECU (R32/Z33-based nistune, PFC, etc) should be your next step assuming you already have an exhaust, FMIC. This will help get rid of the factory overly-rich AFRs. It might also be worth considering your fuel-pump if this hasn't been replaced already. They do tend to wear, and require replacement.
Hi, yes i have FMIC and CAI and 3inch turbo back+hi flow cat, stock 5psi actuator seen 134rwkw, now i have r32 actuator im hoping at least 30rwkw increase, and then push for another 30 with a tune or something without changing turbos, surely you can reach 200RWKW off a stock rb25det with little mods I have mentioned? thanks
And then for some strange reason, at some point after these mods 200kw just wont satisfy any more. Keep in mind that everything else on the car will need replacing/upgraded sooner or later if the power output is increased significantly.
Once you make the decision to modify your car, there is no turning back.
Just a warning haha
I ran my car with the stock turbo on 12.5psi making roughly 215rwkw. The supporting mods were, Coilpacks, FMIC, Turbo back exhaust, Power FC, 740cc injectors (however you won't need to upgrade injectors or AFM to hit 200 rwkw). So a small list of mods should see that power figure :D
just chuck it on a hub dyno and make 200 as is!?
heey guys, just wondering since changing the actuator to R32 should I get a tune? like the car runs quicker but still average at the 0-60 mark? can i tune my standard ecu at all? will it make much difference? or wat should i, could I do to make the car have more response?
mate, take this advice onboard and run with it coming from sum1 who has spent hundreds of thousands of dollars on cars in the past 5 years...
like a few other members said once u get to that "200kw" mark u NOW want once u acheive it u wil want 250, then 300 n so on, TRUST US, u wil, its a like a drug lol
go straight for a power fc, easy to tune and retune afta other mods r put in place (always pop up for sale on here and ebay)
next would b fuel pump and z32 afm
afta that id go coil packs, and direct replacment injectors
and finally turbo (either garret or precision)
if i were u id save all ur penny and do this at once, yes it may cost arounfd 5grand but if u do 1 thing at a time, retuning it everytime to support the next mod
u wil spend thousands just on tuning when u could b spending that on quality upgrade mods and get a 1 off tune...
beauty of have say 250-300rwkw is if u want that 200kw u want just turn the boost down (high boost switch is fun n convenient :)
i think every1 here wil agree with this post, save time, money and go have fun....
Yep totally agree with the post above. Spend all the cash on buying all the upgrades then save and have them put in or DIY and then get a tune. Otherwise you will end up paying a crazy amount on a mod upgrade and tune.
Most things you won't worry about getting a tune with, for example putting that actuator on, you really don't need a tune but look at getting an aftermarket ecu as the stock ecu's are no good for tuning :D
So you want more and more and more power, and a GTR style body kit .... why don't you just buy the right car = sell your Gtst and buy a GTR. It is the only real answer. As everyone has said above, you will continue spending significant amounts of money to get more power .... start on the right foot and just buy a GTR!
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
