Hi everyone,
As topic suggests, I am looking for smash repair places in south Brisbane near Crestmead/Waterford areas. I searched up for similar topic and contacted DMD The Image but their number is disconnected.
Is there places that you guys could recommend that specialise in body kit repair? My front lip got two 10 inches cracks on both side under indicator lights from transporting and I am going through insurance.
Any information would be much appreciated.
Thank you.
https://www.sau.com.au/forums/topic/375771-qld-smash-repairs-south-brisbane/
Cameron's Bodyworks in Coopers Plains. Really nice guy and very good reputation for quality work. His pricing isn't too bad either.
Oh and yes he specialises in body kits and what not.
Thanks, Hieu. I will give them a call in lunch time.
Are there any other places that are ok with fixing body kits around the area? I will have to get 2 quotes for insurance purpose.
Thanks.
oh theres also aero image garage. http://www.aeroimagegarage.com/ Anthony is really nice and I've only ever seen good stuff from him. Might be a bit closer to where you live as well.
Thanks for that again, Hieu.
Now I got 2 places, so will be making phone calls tomorrow. :)
Thanks, guys.
bit late - bradys body works -= coopers plains. he's built quite a few bonnets for me. never had an issue with cracking or bad paint.
Thanks, Chris. I will drop by and get a quote from them if one of the other two don't go well.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
