Got to admit I enjoy watching it. Had some great cars on the last episode,
lexus LFA, 600HP Fiesta Rally car, and briefly a v10 R8 Audi.
(Hopefully they will test the R35 GTR soon).
They are funny enough.
The AUS Top gear is painful.
I think its the aussie accent, it sounds uneducated, the 3 of them look stupid, and aren't witty enough for what the show needs.
Because I like cars I still watch it, but regret it afterwards- like you would after picking up a fat chick.
Edited by scarf
https://www.sau.com.au/forums/topic/376359-top-gear-usa/
  • 4 weeks later...
  • 3 weeks later...
So i watched all the episodes over the past week, and its fantastic. They have a lot of their own challenges and ideas, and most importantly, its rarely boring and always funny.
Their guests leave a bit to be desired, but who really gives a shit about that anyway
its also nice that they give the brits shot about their cars
https://www.sau.com.au/forums/topic/376359-top-gear-usa/#findComment-6071494
It's a damn nice change to see a postiive thread about USA Top Gear for a change. I was opening this thinking "great... here we go again... biggot central" but I was so glad to be wrong!
The US version is fantastic! I've seen every episode to date so far. Watching them in order helped me get into it a lot too, as you can see them from the very start sort of fumbling a bit, then finding their perfect rhythm to make the show really entertaining.
I don't know if anyone agrees, but the three hosts seem to be very similar to the three UK hosts personality wise (like, if the three UK guys grew up in America, that's pretty much what they'd be like), so it keeps that same sort of dynamic going, but we get a totally different spin on things.
I'm glad they seem to have moved Tanner more to the front as the "main" host. He's the most entertaining and knowledgable of the group, and seems more comfortable in front of the camera.
I've had just as many laughs from two seasons of this Top Gear that I get from two seasons of the UK Top Gear.
https://www.sau.com.au/forums/topic/376359-top-gear-usa/#findComment-6071899
I dont think there is too much in common with the UK and US hosts. The only equivalent host would be Ferrara and seems to put it on a bit. Given time i think he'll come into his own.
With Tanner on the show, i like that the stig is only really a lap time guide. Never really been a fan of that aspect.
Look forward to them doing more car reviews and less challanges. Selfishly i suppose, i want to see more of the Aventador
https://www.sau.com.au/forums/topic/376359-top-gear-usa/#findComment-6072417
I've downloaded all of Season 2 (and love it) via bit torrent, but can't seem to find anywhere to download Season 1, anyone got any links ?
I got my season one (720p) via torrent from the pirate bay (I found it via google search).
https://www.sau.com.au/forums/topic/376359-top-gear-usa/#findComment-6075599
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
