Hi all,
I was having issues with my RB30DET related to knocking/pining.
http://www.skylinesa...1076-rb2530det/
These issue have been fixed now, however now I have a new problem. My setup will simply not make the power it should/did on another car. Its as if it is hitting a power "ceiling".
My setup is as per below:
Parts
R32 RB25DE head
RB30 Series 2 bottom end
RB26/30 CP Pistons 9:1 Static CR (CP pins, rings etc.)
Spool RB30 Rods to suit. ARP fasteners
ACL Race series bearings to suit above rods
Standard Crank. Blueprinted/Balanced/Crack tested etc
RB25DET Series II Oil Pump with extended drive "Snout" (Spool Imports)
GT3076R 0.82 A/R Garret Turbocharger (Standard oil/water lines)
Stiffer valve springs (unsure of brand)
High Energy Style Sump + Head drain (big f**k off fitting on the back of the head)
Standard valve train (RB20DET) (Cams/gears/lifters etc)
Cometic Head gasket (Spool Imports)
GTR Waterpump
550cc Bosch EV14 Injectors
Nismo Fuel Reg (Adj.)
Nismo Engine Mounts/G-Box Mounts
Bosch 040 Fuel Pump
Nistune ECU Remap
Labour
Bore/Hone Block to suit CP Pistons
Deck Block
Grind/Blueprint Crankshaft
Balance Pistons
Micropolish Crankshaft
Balance Motor
Reconditioned Head
Modify/Weld/Machine Head
Now no matter how much boost, timing, fuel etc. the tuner threw at the motor, the car will just not make anything more than about 210-220RWKW. Don't get me wrong its decent, but its no where near where it should be. This exact turbo on Cube's RB30 made (on standard RB25DE cams) 260RWkW. Id expect something a little less than this considering that I'm running RB20DET cams instead. I would also expect it to make it on less boost considering that I have a higher static compression ratio than him.
To my knowledge the motor is running 20-22deg ignition timing on full noise, 18PSI Boost, and the AFR's are sitting between 11-12:1.
Run more timing and the thing wants to ping but make no more power.
Run more boost and it makes little to no (few kW) difference in power and just generates more heat.
Run more/fuel (within reason!) and it only makes a few kW difference in power.
Another interesting fact was that previously when the motor was knocking, it was making 220kW on approximately 8 degrees worth of ignition timing. Which to me would seem as tho the car had been incorrectly timed (CAS error etc.) and that the motor was ACTUALLY seeing something closer to 20 deg of ignition timing. But I cant state that for sure...
We are dropping the exhaust/intake to see if there is a restriction in there somewhere limiting the setup. Failing this...Is there any other ideas/experiences that people have had hitting this "ceiling" with similar setups on RB20/25/26/30's?
Edited by R32Abuser
https://www.sau.com.au/forums/topic/376666-power-ceiling-gt3076r/
  • Replies 88
One of the cams is probably out a tooth
how does it drive?
out of curiosity. Ive just got my 25/30 up and running . un tuned still running rb25 tune.
I hear that they hit full boost 2.6-2.8k with a 3076R.
I am currently nowhere near that lol., I am presuming its because it is still yet to be tuned ?
I bet it is running as lean as f**k, mine did with the 25 tune in it. Stop driving it or get it to a tuner stat.
yer man. my narrowband hits the lean as soon as she comes on boost.
i was picking that as she was starving for fuel/ no timing put into her created the extra lag,
tune time next week, should woop it into gear
not unless your only running 5-10psi. in the real world they make 1 bar around 3200-3500 depending on the setup.
No matter which way you look at it the next step is to drop the exhaust and see what happens
DVS JEZ
The pinging/knocking issue was alleviated once we fit the RB20DET cams, new CAS, and re-timed the motor. Which one solved the issue I don't know. Im just glad it is no longer pinging to be honest and the fact that the pistons weren't the issue after all worship.gif
Intake setup is as the following pictures:
No rubber intake to turbo. Solid 3" aluminium pipe. Other than that, standard on the intake side besides a hole in the airbox. Possibly routing a big arse PVC (painted black) pipe setup straight into the airbox. May do this if it becomes an issue for power.
Dyno Im unsure of but here is the link to the site:
http://www.morpowa.com/dyno_dynamics.html
Tyres are as follows:
R: 235/45/R17 Bridgestone Potenza RE001 Adrenalin. Practically brand new.
kitto
Standard RB20DET cams. Possibly upgrading to custom re-grinds down the track pending how this setup goes.
sriver killer
I haven't driven it myself, but from what Im told drives very well. Nothing too ball tearing as its down considerably on power, but torquey as! Apparently (according to Cubes) this turbo will hit full boost 16PSI by about 2800-3000RPM.
Overall this could be a cam issue. If dropping the exhaust/intake doesn't fix the issue, we will be checking the timing again to make sure.
Exhaust s fine. 3.5inch turbo back with 100 cell cat.
1 bar at around that RPM is what I am getting, 4th gear on highways only though.
DVS JEZ
http://www.morpowa.c...o_dynamics.html
kitto
sriver killer
I am picking as I have the 25 tune the timing/fuel delivery is way out. giving me the unnecessary lag.
Driving around town the 30 is THAT much better to drive.
You would't think the difference that 500cc+ extra crank weight could be so noticable. Even with the 8.3:1 comp ( I am running new cast standard pistons)
Btw it probable doesn;t help my delivery that I have a 6boost, + plazmaman, + 3 inch intercoolerpiping + 4 inch thick intercooler
IMO a 4" thick intercooler and 3" piping is overkill for your power level. Obviously this will depend on what your using it for (street/track/drift/dyno queen). Either way, the time/airflow required to pressurise/fill these pipes would kill your delivery if you were aiming for near stock spool times. I assume that was what you were aiming for with the GT3076R turbo choice?
6Boost plenums from what I have read tend to promote power generation higher up in the RPM range as opposed to down low. So yes, this would not help your cause either.
Edited by R32Abuser
The 4 inch cooler was a necessary upgrade as at the time, as my existing 3 inch china ebay cooler had pressure drop issues.
3076R was purchased as a good all rounder, I can;t justify a 35R as a daily driver turbo on a rb25
Ive had everything just in case I want to upgrade turbo in the future.
what do you guys reckon about the garret .70 A/R front housing(with drilled anti surge slots) instead of the hks style .60A/R front housing?
exhaust comment was aimed at the OP. yer you'll only get 1 bar at those revs under a lot of load. it'll be a fair bit higher in lower gears
6boost manifolds are generally better all round, i highly doubt you'd have noticeable more lag over a stocker
Yup. I knew it would be touch an go with a 3". Has been done before, but figured I would just sneak it in. We'll see if its the restriction come Monday (dyno that was supposed to be used on Friday was unfortunately occupied all day due to a head gasket failure and prep. for a race on the weekend dry.gif
Either way, I'm looking for a more conservative 3.5" cat-back system. Anyone know of a 3.5" off the shelf cat back exhaust which is not too harsh on the ears (read: retains a centre muffler!)?
Sooo...The plot thickens!
Exhaust dropped - Car made no extra power (210kW)
Airbox dropped - Car made no extra power (210kW)
Cam timing will be looked into...Builder is doing the rounds for some opinions for this problem.
Very Frustrating :rant:
Cube's old GT3076R....
GT3076R .6 Port Shroud Comp Cover .82 Internal Gate
3" turbo back exhaust, Bell mouth 3" dump
Dont have the CHRA number on hand. Can get that for you though when I see the car...
Been talking to Sydneykid and he said that there isnt one RB30 he has built that hasn't needed timing adjustment. In this case I spoke to my builder and he said that at most it would be out a tooth but he also mentioned than although the lines are 100% spot on...they are barely noticeable out of alignment.
Adjustable cam gears possibly an option?
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
