  • Replies 134
Richo,
Wouldn't you happen to have 2x metal brackets is being used to hold the number plates by any chance?
The black thing on bumper, being screwed into reinforcment bar.
You talkn about the rear or the front? The front is held onto the front bar only, not the reo. Don't have those one, will have gone with the bar.
Have the rear one.
After front.
They're held into front bar? Thought it's held with reo after seeing threads on the reo of my GTR.
Oh well, thanks again.
have the cluster surround x2. So if yours is covered in leopard print, or you want to cover your in leopard print, get a spare here. $20 ea
both clusters gone
have a dash surround left, painted in black, no cracks. Same price as the first page.
Got heaps of arms, front arm price in the first post.
Have castor rods x2. $70ea
Have upper control arms. $70ea
all the arms in the rear, which do you need.
have two sets of rear brakes. $150ea pair, come with pins and retainer.
more more more, pm me
both gear surrounds and dash surrounds gone.
Still have 2x cluster surrounds, the cluster are gone though.
Have the inner door cards in good condition etc.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
