I AM SELLING OR SWAPPING MY LOVED R32 SKYLINE GTST.HAD SO MUCH PLANS FOR THIS BUT PLANNING TO SAVE FOR A HOUSE.PLEASE NO LOW BALLERS OR STUPID OFFERS.IM NOT IN A RUSH TO GET RID OF THIS CAR BECUASE I LOVE IT.
REGO:FEB 2012
1.ADJUSTABLE CAM GEARS
2.GATES TIMING BELT
3.KOYORAD RADIATOR
4.STANDARD AIRRBOX WITH STAINLESS STEEL INTAKE PIPE AND COLD AIR INTAKE PIPE TO AIRBOX
5.STRUT BAR
6.YELLOW JACKET COILPACKS
7.HKS BOV RELOCATED TO FRONT BAR
8.D1 SPEC CATCH CAN
9.ALL WIRING FOR SUB AND AMP IS THERE JUST NEED A SUB AND AMP
10.T3/T4 TURBO
11.3 INCH TURBO BACK EXHAUST
12.GTR INJECTORS 444CC
13.GTR RESISTOR PACK
14.SERVICED ITH MOTUL OIL AND DRIFT OIL FILTER
15.HID'S
16.LOWERED AND KYB SHOCKS
17.TOMEI PONCAMS
18.DUAL STAGE BOOST CONTROLLER WITH SWICTH BUT SWITCH IS NOT CONNECTED
19.CLARION DVD HEAD UNIT
20.MOMO CORSE STEERING WHEEL
21.AUTO METER BOOST GAUGE
22.NISMO SHORT SHIFTER
23.NISMO GEAR KNOB
24.HAS SCRATCH AS SEEN ON PASSENGER SIDE
25.ROOF NEEDS RESPRAY
26.NISTUNE NEEDS A RE TUNE
27.DASH LIGHTS FLICKER
28.GTR REAR SWAY BAR 24MM THICK
29.FMIC
OTHER PARTS FOR SALE:
1.R34 HIGHFLOWED AND STEEL WHEEL TURBO
2.38MM TURBOSMART EXTERNAL WASTEGATE
3.STANDARD EXHAUST MANIFOLD
4.STANDARD REARSWAY BAR
5.ALLOY REAR SUBFRAME BUSHES BRAND NEW BOUGHT FROM JUST JAP
6.WALBRO 255 FUEL PUMP
7.BRAND NEW SARD FUEL PRESSURE REGULATOR
8.BRAND NEW HPI DUMP PIPE MADE IN JAPAN
THATS ALL I CAN THINK OFF AT THE TOP OF MY HEAD.
PLZ TXT MY PHONE YOUR OFFER AND QUESTIONS THANKS
post-84737-0-55139300-1315816471_thumb.jpgpost-84737-0-18652000-1315816496_thumb.jpgpost-84737-0-68887700-1315816514_thumb.jpgpost-84737-0-75292900-1315816529_thumb.jpgpost-84737-0-87378100-1315816555_thumb.jpgpost-84737-0-61960600-1315816569_thumb.jpgpost-84737-0-61960600-1315816569_thumb.jpgpost-84737-0-20931900-1315816583_thumb.jpgpost-84737-0-76403300-1315816604_thumb.jpgpost-84737-0-32259900-1315816619_thumb.jpg
https://www.sau.com.au/forums/topic/376965-for-sale-or-swap-r32-gtst/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
