the best tuner for nistune is Yavus at Unigroup engineering,
http://www.unigroup.com.au/Home.html
contact details on this site. this guy is one of the best tuners in sydney, if not the best.
well mods are
ARC induction box
ARC side mount intercooler (but will be installing a front mount soon)
Splitfires (soon to be installed)
RB25 turbo
3 inch dump and 3.25 exhaust with hiflow cat
apexi avcr
new gates racing timing belt
adjustable cam gears
Z32 afm (replacing this with stock afm)
i think thats about it........
looking to only run what my car will handle with having the standard injectors in it
which im thinking will be about 12.5 psi to 13 psi my aim isnt for mega power, just
what she is going to produce i will be happy with :) whos going to argue with 170rwkws :P
im installing the standard AFM cause i shouldnt need the Z32 on my setup and the car
should run better with the standard AFM
also fogot to say im installing a FPR to get a little more pressure in the system and threw the injectors
and also i got a bosch 040 fuel pump installed!
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
