OK now im pretty sure its the bushing, Corect me if im wrong? but its Cracked. the Oval shaped peice.
I need the exact name of this part as im going to have to call the wreckers to try get a new one. will i need a whole Rear controll arm?
cheers p.s Rear 33 GTST hubs i have, in the pic are 34 hubs
https://www.sau.com.au/forums/topic/377353-rear-hubs-pics-included/
Rear HICAS ball joint. Can buy them off the just jap site for about the same as from Nissan
Does this look like it? (making sure we are Talking about the same thing)
http://www.justjap.com/store/product.php?productid=19362&cat=&page=1
Edited by 89CAL
That is f**ked, unless you can get it welded back up i would be getting another one from a wrecker. I think the wrecker will just call it a hub assembly, tell them it is the part that all the suspension arms attach to it might make sense to them
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
