It is very common for bench press strength to gain slower than others.
Not many people aer great benchers.
Also, it is important to note that to have a strong bench, you need strong lats.
So for every push exercise you do, you should be doing the equivelant if not more in a pull exercise.
Doesn't matter if you can't do 5 chins.
you will eventually.
There was an interview of a champion powerlifter where they asked him "how did you get so strong in the deadlift" and he said "To get stronger in the deadlift, I deadlifted"
If you want to get stronger in Bench, do a lot of bench.
Every second day.
and super set every bench set with a set of chins or bent over row/seated row/t bar row.. whatever you have access to.
I train at home in a shitty power rack and on a shitty bench.
I do a set of bench, stand up and grab the chin bar over head and do a set of chins, then rest
When I train at PTC Brisbane, he has a proper bench press setup. So I set up a loaded barbell next to it. I bench, then I do a set of Bent over rows using the same weight I benched, then rest..
you get my drift.
if you don't have elbow problems, keep doing curls.
just leave them till the end of your session and just do a couple.
maybe try 40kg for 5 reps one week.
bodybuilding.com is ur friend have a look on there and get tips and correct eating habits from professionals they also have massive amounts of training schedules for beginners to advanced.follow them and u will see results
Yeah... sorry man but BB.com is in no way a go-to source for workouts. It is by far the biggest collection of bro-science on the web, and you will end up looking like a gorilla with all the anterior chain work in their programs.
  • 1 month later...
quick update, dont know if i mentioned i had a couple knee issues from oztag which seems to have been relieved. I havent got back to my previous squat and deadlift weights but I am slowly getting there.
been training pretty solid as of late. My spotter has moved into doing more of a volume routine with 5sets of 10-12 reps whilst I've changed it up to a more of a 4day split focusing on strength.
Push A:
Barbell Bench
Standing Military Press (after i finish with my sets here, my wrists are in some major pain. Anyone have some ideas how to sort it?)
Standing Dumbbell Tricep Ext
Squats
Calf Raise
Pull A:
Seated Row
Wide Grip Lat Pulldown
DB Shoulder Shrug
DB Bicep Curl
Romanian Deadlift
Push B:
DB Incline Bench Press (probably my favourite exercise)
DB Shoulder Press
Dips until failure
Leg Press
Calf Press on above machine
Pull B:
Normal Deadlift
Pull ups until failure
barbell shrug
barbell curl
lying leg curl
Diet still sucks balls. Got to get into a better routine for food. Morning food is a bit of an issue because i have developed Reflux for some unknown issue so morning is the worst meal for me.
couple of old shitty photos:
Late last year or early this year:
Two months ago:
pretty sure im weighing in at about 70-72kg in each photo, second has more muscle but still a little bitch
Tonight's workout.
Incline DB chest: 27.5kg by 6reps for three sets
DB Shoulder Press: 20kg x 8reps for 2 sets
22.5kg x 4reps
Dips: 12, 10, 10
Leg Press: 130kg x 10reps
170Kg x 8reps two sets
Calf: 170kg x 10reps for three sets
starting to plateau a little with strength, but I also think its a bit of inconsistency as far as diet and even the weight that I can get my hands on.
Anyway last nights workout:
Bench: 60kg x 8
60kg x 8
60kg x 6
Standing Military: 35kg x 6
35kg x 5
35kg x 5
Standing DB Tricep Ext: 15kg x 10
15kg x 10
15kg x 8
I was meant to do squats but I hurt my knee at Oztag again last week. Same issue as last season so I've started to do the rehab exercises that the physio gave me. The issue flared up again during calf raises.
Cheers,
Cable Seated Row: 40kg x 10
55kg x 10
55kg x 7
Lat Pulldown: 68kg x 6
68kg x 6
68kg x 6
DB Shrug: 32.5kg x 10 every set
DB Bicep Curl: 10kg x 10 every set
Really struggled getting any weight tonight. Apparently if you put 800kg onto an olympic bar for squats, then proceed to lower yourself 2 inches you are considered big and strong.
oh and people seem to think that they need to use every DB in the gym whilst doing flat bench....
As something to throw into the getting stronger at bench mix. Two things.
1) Shoulder girdle excersises. Your rotator cuff is very easy to hurt. If you plan going for weight on the bench I reccomend some excersises there. If the shoulder girdle is weak you will issues.
2) You can try some 'static holds'. This is hold for upto 6-7 seconds , typically at full contraction point but, with assistance you can target different points in ROM. You will do alot more weight than normal. I found it assists in the innervation feedback and it's not uncommon to see large strength increases after some weeks training with it.
  • 2 months later...
funny story, i was sitting at 71kg pre holiday.
go to the states, eat real shit food and came back 66kg....
starting gym again tonight, going to go with a simple full body compound workout for a few months to get back into it.
something like this, not sure on the rep range, either aim for 10 reps or a 5x5 program:
Pull Ups
Squat
Bench press
Seated Row
Military press
Deadlift
BB curl
Edited by -FIGJAM-
Mate, I decided to start training when I was 22, and i weighed 62kg and am 6'4" tall and have an extremely fast metabolism such as yourself.
When I started training i was doing a full body routine 3 days a week, just like when you started. I put on 15kgs in the first 6 months!! And it was all lean muscle.
What i was doing was changing my eating habits. Its all about the food my man. 80% eating 20% training.
You won't grow if you dont eat.
Before bed i would make a 2L blender full of the following:
2 weetbix, 2 eggs, 1 banana, 8 scoops mass gainer protein, 2 scoops vanilla icecream, a bit of honey, fill with milk.
Blend and drink half 30 mins before bed. Put the rest in the fridge.
Get up in the morning first thing, reblend and drink the rest.
Only had my usual (at the time) 3 meals a day, but also had protein shakes before and straight after training.
Then would make the same shake again before bed.
Makes a big difference.
I am now 30 years old, still 6'4", training 5 days a week with a full split program and have hit a peak of 102.5 kgs with body fat of around 12-15% and i do no cardio and eat 4 to 5 times a day, plus 4 protein shakes a day, plus snacks, plus around 6 litres of water a day and the rest of the training supplements.
Like i said, no eat, no grow.
If i do cardio (walk 3 times a week for 30 mins) ill lose around 5 to 6 kilos in two weeks (know this from last summer lol).
Try the blended shake before bed and when you wake up and see if it helps. It helped me ALOT!!!
I was asked all the time if i had started taking gear and i just used to laugh.
Lol sorry but what now?? ^^^
If you were truly lean, there's no way in hell you could lose 5-6kg in two weeks from simply walking. You're no where near as lean as you say you are if that's the truth.
Yes he needs to eat, but not 4 protein shakes a day. That's ridiculous, and expensive. Id rather eat a can of salmon any day of the week.
12-15% bodyfat isn't lean, it's average, and if the only way he maintains his weight is by smashing food then I can easily see him losing weight fast by reducing calories and adding cardio.
Liquid calories are the easiest way to consume a lot of calories, for a hard gainer this is a handy tool to have in your toolbox...
Edited by GHOSTrun
TM7GTR, When I say walking, its a very fast paced walk, almost on the verge of a power walk, not just a stroll.
And at 102.5 at say 15% body fat (15kgs fat total weight) i lost 5 to 6 kilos in two weeks. Yes there is also marginal muscle loss which goes with all weight loss. Dont forget i am also training my ass off for 5 days a week for an average of 2 hours a day. So i am also sweating my ass off at the gym.
I also have a stupidly fast metabolism and it is extremely hard for me to gain extra mass no matter how hard i train or what i eat, but very easy to lose it. And unless you are in the same boat (not a five foot nothing midget who makes it look easy to put on size), then you wouldnt have a clue. I put it up here to help a fellow gym goer who is in need of some guidance. Not to just hear from nay sayers.
And no im not less than 10% body fat now because i have since put weight back on after 1 and a half years of training to gain that 5 kilos back.
Yes it is expensive, but its not rediculous. If you want to be your best, you have to pay the price and do what ever you have to do to get the job done. Thats the difference between being determined to train to your full potential, or just being there and going through the motions pretending to want it.
    • Your chihuahuas look weird!
    • Call me the "Crazy Cat Man"...., maybe that should be my new forum name....LOL....., but seriously.....someone change it please, thanks Just grabbed the two black Oriental kittens that I ordered a few months ago to guard the house, I am assuming that because they are Orientals they know KungFu, Karate, or are Ninjas, or some other lethal fighting skill, even at only 3 months old they already have Parkour down pat Introducing...Bella & Donna
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
