Hi everyone,
I'm only just thinking about this at the moment tell if this mod is worth it? what does hi flow mean?
I plan on getting an exhaust system for my R33 GTST it is a 3'' cat-back from the turbo with 2 4'' mufflers on either side of the car. Hi tech mufflers have quoted me $1000 for the job. do you think this is worth it? will i get a slight increase in power/ performance?
Thanks for all Da help
slyline
https://www.sau.com.au/forums/topic/37743-what-do-you-think/
a dump pipe is the outlet pipe on the exhaust side of the turbo, high pressure off the turbo is pushed out through this pipe, when you run higher boost pressure through a different turbo other than the stock one, the stock dump pipe becomes a restrictrion, also probably when you run higher boost on the stock turbo, as its a restriction point. if you are getting a full exhaust, you should get a dump pipe too, and also a front pipe to increase both airflow off the back (exhaust side) of the turbo and to the front (air intake side)
hi flowing involves getting your stock turbo, replacing the compressor wheel and blades with new and usually stronger parts so you can run a higher boost than the stock limit, if you run your stock turbo at about 14psi it will go bang sooner or later as the compressor wheel can't handle that high amount of pressure for too long, higher pressure = more heat = compressor wheel go bang. when its hi-flowed these parts are much stronger and you can run up near 18-19psi on a hi-flowed turbo (well the stock r33 one anyway) its comes out to about 450HP turbo, or there's a 500HP variant too, from gcg turbos in sydney. to hiflow is about $1800-$2000 and its done on your turbo, or as a trade method, you send in your stock turbo and the money, they send you out a hiflowed model.
someone else may be able to add some more info, i think my descriptions are correct
https://www.sau.com.au/forums/topic/37743-what-do-you-think/#findComment-760637
the main advantage of getting a hiflowed model of your stock turbo is that will bolt directly back up and anyone can put it back on or take it off as its just standard bolts, no other changes need other than a boost controller.
if you get a different aftermarket turbo (hks/greddy/apexi/garrett) then you may need a different manifold and youll need to match up the water/oil/exhaust lines so that it fits correctly, which can be costly. with a highflowed model you dont have to worry about it
https://www.sau.com.au/forums/topic/37743-what-do-you-think/#findComment-760646
Guest INASNT
Hi everyone,
slyline
Is that for mild steel or stainless?
https://www.sau.com.au/forums/topic/37743-what-do-you-think/#findComment-761214
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
