I love this pic........................... :rofl2: !!!
Anyways.............update of whats planned in the near future.
> Repaint the front lip
> Clean the insides of the other 3 rims
> Keep saving for work meisters
@landscribble.....come to think of it now James (10 4) did mention you ages ago in one of our random car related chats.....and yeah I often drop and pick my sister from uni so that would explain it.
Update:
Work roster is hectic (lots of people on leave at the same time - slackers!!) and coupled by the fact that I am saving for the rims now car stuff has been put on the back burner sadly.
Did however pick these up yesterday (enough of struggling with miniscule rachets)......and plan to spend a couple of hours on my days off scrubbing my current rims till they are squeaky clean !!
  • 4 weeks later...
Not a lot has happenend........................
Had a squeaky clutch pedal......................two sprays of WD40 and that was nipped in the bud.
Went down to Barbs this morning with the lads.........lovely sunny day and some nice rides.
Doing some touch up paintwork this arvo......window wipers getting a touch up and the rear bar corner.
In other news.............I might be getting a bucket seat soon............................. :yes:
you bought WD40! haha
^^^^^ :thanks:
Today is seat day.....
First up....I highly recommend a GTR seat.....works wonders.....I am so snug in it now its not funny.....its comfortable yet firm....holds you amazingly well yet is easy to get into and out of....and yeah bolts straight in so no dramas.....fifteen mins and I was done (with the fitting it in I mean)
HOWEVER.........................................being anywhere between 15 to 20 years old these things can get a bit "rugged, tired, worn" etc.
Started off with something like this..............(didnt take a picture so stole one off the internet)
Took the old seat out (remembered to take off the seatbelt sensor plug)
Then "attempted" to put the old leather covers on..............
For those of you who have seen a GTR and a GTST seat you will know that while they are similar in design the top bit is totally different.....the GTST having a separate head rest.
Time for some innovation...
There was no way I was going to leave it like this.........................so I put on my thinking cap and called in backup
Does this ring a bell........................
My car is called "Night Fury" and for those who have not seen "How to train your dragon" this is what its named after
Well so did a little bit of this....................................
and then "backup" did a little bit of this....................
and then I did a little bit of this...................
and then a bit of this.....................
A BIG THANK YOU..............because you are amazing !!
This is how its going to be for now.......................before I put in some big bright yellow and black eyes sometime tmrw possibly.
:wub:
Will post finished pics when I am done
^^^^^^^ I would say so myself...hahahaa...and :thanks:
Made the eyes this morning............
Then glued them to a leather backing that I carefully cut to the same size......put bits of velcro on the back and hey presto...we have ourself some eyes.
Ok....im working on something and the bloody front grill clips are a pain in the ass :angry: Feel like just wrenching it off :rant:
Also....................I am painting the bootlid badge...and its looking good :P Pics to follow soon
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
