  • Replies 125
sammy would have done her out the back on sat night in the state he was in.
well he did disapear for a while there and was heading to the "toilet" at the time right near where she was!
/puts pinky finger to corner of lip and raises an eyebrow
i remember sammy screaming out "HEY THERE'S TWO GAY GUYS IN HERE, CAN YOU GIVE US SOME PRIVACY" while he was in the cubicle doin something or other...
lol don't know if that was the exact comment but the other occupant is a member of these forums (no, not me)... they were smoking in the toilet since femi-nazi no. 28 wouldn't let peeps outside for a breather...
he prod did, atleast no one would have said anything or thought he was pissed when driving out of the crown carpark coz he was parked in the diabled spot for the whole of saturday. They would have just thought he was really retarded!!! hahahahaha
lmao well driving home in his state was really retarded so i guess that parking spot was kinda fitting :)
Thanks for everyone who came, helped and made it a sensational weekend for all.
SAU/FA had the biggest stand, the best cars - and the power to boot.
Well done to all.
My boot was something to be proud off! :D
Now i'm gonna go and clean it out :(
Matt, you should come to more SAU meets.
If we aint cruising we are drinking... i wonder why :D
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
