Over the Christmas holidays, I plan on driving my Line up to Geraldton to see family, the only problem is I usually only get around 300kms a tank, so I'm wondering if anyone is aware of the availability of any 98 fuel between Perth and Geraldton?
Jezz.
https://www.sau.com.au/forums/topic/377704-availability-of-98/
300km / tank? Ouch.. Would kill me pinch.gif
OR, delete factory o2 sensor, replace with wideband and learn how to tune cruise AFR's = 600kms a tank ;)
I'd pay to see someone do 600km on a single tank in a skyline, I really would.... Haha
How much and when are you free? Lol, my car does it easily. I average between 590-600ish. It's not hard to do, but most people don't venture into tuning their car themselves. There's some gains to be had between the dyno and the road, especially considering most tuners won't spend much time on your cruise AFR's.
I quite often do long trips in the Stagea and going from ~350km around town I get well over 500kmh once on the highway.
I plan my trips around BP locations (can now use Shell 98) and carry two full 20L jerry cans in the back.
Also good to have 2 spare wheels, a bottle of oil and 10-20L of water :thumbsup:
Wow 300kms a tank?
When i had my R33 gtst, on country roads sitting at 110km/h constantly, i reset my trip metre/odo and to a single tank i got almost 700km.
That had ebc, fmic, turbo back exhuast, pod, tune (making 280rwhp) and it used bugger all fuel on country driving.
Wow 300kms a tank?
Good son of rajab that must have been running ridiculously lean at around 3000rpm, did you ever notice surging??? I get worse economy driving at 100/110kms, a good 3L per 100km worse than I do at 80/90km. The engine just needs that much more fuel at that load/rpm.
E39 528i, 100kmh, 6.6L/100km AC + radio on., theoretical full tank economy of 1060km worship.gif
Martin, my old 32 (one over east) could get 650+km/tank sitting at 100 solid and that was fairly powerful... Something not right with your car....
Edited by 10 4
Are you taking the coast road to gero? Jurien has a Bp so i'd assume it has 98, theres also a caltex.
If you top up your tank there you'll make it the whole way easy.
Theres a few other petrol stations on the way aswell but i dont know if they have 98, just take a bottle of octane booster with you.
If you make it to dongara before you need some, they have a shell and a bp on the highway.
Geraldton has a gull and a bp on the highway in.
If your going the inland way i dont think cataby has 98 anymore so you'll probably just have to fill it up with whatever they've got or take some octane booster aswell for piece of mind
t need some, they have a shell and a bp on the highway.
Nah I don't think I will take the coast road, that's Badge that has caltex yeh?
I guess I'll take a few octane boosters for peace of mind haha,
Cheers for everyones replies,
Pretty sure badgingarra is shell, I think eneabba is shell aswell.
Personally i wouldn't take a jerry can, just fill up with what you can and if its shit don't thrash the car until you get another tank of 98.
You should see if you can sort out whats causing your high fuel consumption, i've done the trip heaps of times and never used a full tank in either my 180 or 31
Cataby has a Caltex, but I think there's only 95 octane. Same with the Liberty servo. Liberty fuel prices are pretty decent, sometimes cheaper than Perth. I've used it many times and runs ok
I can do over 550 in my Calais which has an RB25DET... std ecu, 10psi.
Refueled around then because I wasnt sure when the next stop was comming up.
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
