So I recently got my R32 back (RB20) after 20 months of it not being started. I charged the battery, unplugged the CAS gave it a few cracks and then plug the CAS back in and started it up.
It was running fine 20 months ago, but now it has a misfire on the 3rd cylinder back. Ive changed:
coilpacks between cylinders, nothing changed,
Ive changed spark plugs between cylinders and cleaned them at the same time, no different,
At this point the car wasnt blowing fuel out the exhaust, the sparkplug was dry and in good condition on the 3rd cylinder. Then I pulled all injectors out had them cleaned and tested all 100%, Still no change, but the the car does seem to blow a lot of fuel now unlike before.
Ive pulled the sparkplug out and put it in the coilpack and cranked it over and I can see the spark firing.
As far as I can tell it has spark, it has fuel and it has air.
Suggestions?
Can an igniter cause problems on only 1 cylinder?
Edited by JiN_MaN
https://www.sau.com.au/forums/topic/377750-rb20-misfire/
Are you 100% sure its #3 even after changing the plugs around? I see you say it has spark, but is it a bright/strong spark?
for 30 bucks I would just chuck a set of new copper plugs in, even if its to eliminate any future problems
https://www.sau.com.au/forums/topic/377750-rb20-misfire/#findComment-6023925
Police took it to investigate and forgot to give it back. :thumbsup:
Will do compression test when I find my compression gauge.
If its ring it should still have some sort of compression and if its valve then it should just be a flat 0. Is that correct?
https://www.sau.com.au/forums/topic/377750-rb20-misfire/#findComment-6026094
No, a damaged piston or head gasket can cause a missfire at idle but not when above 1000rpm. Compression could come back 100% as well.
Valve can be the same. RB's aren't well known for carbon buildup on valves or ports but it can happen.
Do the comp, if it's 100%, do a proper leakdown test
https://www.sau.com.au/forums/topic/377750-rb20-misfire/#findComment-6026223
Injector plug was the issue.
When all the way on with the c clip it wont fire. When pulled half way off it fires. So pulled all the injector plugs off and gave them a clean, now running 100% :thumbsup:
I thought you checked the injectors?
https://www.sau.com.au/forums/topic/377750-rb20-misfire/#findComment-6038356
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
