Hi Guys,
New to this Forum and low and be hold I come to you Skyline Guru's for some help if you would not mind.
I have just bought a set of POD Filters for the car and have Installed them Myself.
The Pod Filters came with Instructions and I followed them Exactly. One of the Beginning Instructions was to remove the Battery Cables so I did.
I have since Completed Installation and Everything was fine Car Started and is running perfectly.
I now have any issue with when I turn the car off and open the door, passenger as well the window comes down 3/4 the way down. I have to turn the car back on to get the window back up but as soon as I try and get after turning the car off it repeats.
I would really appreciate your help if you can. I have spoken with Nissan and they have told me that I have to reset the Computer does anyone know how to do this as the Earliest they can fit me in is Tuesday next week which is not the best as I need to drive the Car and they want to charge me $130.
Thanks Scott
https://www.sau.com.au/forums/topic/377834-nissan-skyline-370gt-2007-reset/
you can also try resetting the ECU without disconnecting the battery
http://www.myg37.com/forums/d-i-y-installations-modifications/175792-easy-way-to-reset-ecu-without-battery-disconnect.html
takes a bit of practice but it's piss easy once you get the hang of it
also, try a little trick that seemed to work on (newer) nissans back when I used to sell them... when the car is on try closing the windows all the way down & click both window buttons down again. Then click them up, when the windows go all the way up click both buttons up one more time.
Saw a service tech do it on a 350z once that had a similar problem, then voila!
  • 3 years later...
Hi Guys,
Thanks Scott
G'day all,
The fix is very simple. Start the car doors closed push window button down and hold for 4 to 5 seconds then up for 4 to 5 and she's done.
