  • Replies 108
Mystique also has no IP address...
The plot thickens...
yes he/she does have an IP...
and - just a hint - i highly doubt this person is a cop...but that's all the info u guys are getting!! - just let em post in their own good time u bunch of stalkers!! :D
https://www.sau.com.au/forums/topic/37786-mystique/page/5/#findComment-781475
Reading between the lines of other posts, I understand Shell is pretty popular in the ACT, something about being a cutie. But then again, geeky enough to extract an IP :)
Careful Gordo.......she could be.......(insert dramatic music)...an admin!!!!
https://www.sau.com.au/forums/topic/37786-mystique/page/5/#findComment-782062
I thought most of you people were computer nerds?
Of course the dang box they're connecting from needs an IP. Jeebus. It prolly just doesnt show up cause either the rego'd on the old forums (which does have an SQL table entry for 'user ip') or it registers 'user ip' on the first post. Or the most recent action.
https://www.sau.com.au/forums/topic/37786-mystique/page/5/#findComment-782871
Neeeerrrrd
now I wouldn't expect you to know how much impulse energy would be required to spall of a scab of rolled homogeneous armour would I, or how to set up a top attack mission profile for a control system? I just use computers, I don't make them talk to each other, thats someone elses paycheck.
Just out of interest is there any way to hide an IP or do you just route it through a dead end that won't pass on any other IP's on your side of it?
https://www.sau.com.au/forums/topic/37786-mystique/page/5/#findComment-783099
yeah...shell...who is it..............................guys lets all send shell 200 pms and block her inbox :(:):( until she tells us who it is :(
hehe Anna... my pm's are full anyway :D
so what's your new plan now girly?? hhe
Geoff :)
pretty close there, not the cutie bit...the admin bit :(
https://www.sau.com.au/forums/topic/37786-mystique/page/5/#findComment-783725
Thats not what I have read while lurking around the ACT forums. Just interested to hear whats going on there as I was one of the early importers there. Come back sometimes to check my rental in Dunlop and go to Timmy's for dinner.
So are they still coming down hard on Braddon meets and the Fyshwick Quix or have the antisocials moved on? Really only became a problem when they shut down the 1/8th mile strip.
https://www.sau.com.au/forums/topic/37786-mystique/page/5/#findComment-783751
aaaah hehe Timmys...and what's the other one, Sammys? Fyshwick quix doesn't seem to be a hangout anymore...and as for Braddon - over it!! - not that i was ever really into it, i was more likely to be in a bar nearby drinking hehe :aroused:
but yeah, braddon and Civic are still the main places people go...
there's been petitions to re-open the dragway...can't see it happening tho!
https://www.sau.com.au/forums/topic/37786-mystique/page/5/#findComment-790924
Christ...do you sleep?
ACT pollies are the most self serving fools I have ever come across, and tend to lack intelligence. Bit like a local council with a bigger stick. The strip is a goner, as is the V8SC race that they blew. Everything that ACT govt touches goes sour. Remember the Hospice demolition and that poor girl that was killed? I'v done some demolitions training and in Defence our safety distance for High Explosive (HE) on steel is 1000m. She was only 350m away. Also the Feel the Power ad campaign on the plane that got grounded? Morons!!!
I was never into the street hangouts, but sometimes I would roll in to catch up with some people I knew and then leave soon after.
So are you sneakily giving all the forum stalkers a day or so without access to p*** them off? :D
https://www.sau.com.au/forums/topic/37786-mystique/page/5/#findComment-790989
yes, from about 5am-midday :)
I remember that very well...i was standing right near her. My bf grabbed me and threw me to the ground as a piece of concrete flew over our heads and embedded itself in the car behind us :D
i was pretty disapointed when they lost the V8 race...the one chance we had to show everyone that we actually hold some interesting stuff here, and we're not just all about flower shows and art galleries... but anyway..
they might have improved crowd numbers drasticly if it wasn't held in June when all canberrans are hibernating cos it's so fcking cold LOL
hehe i think the forum stalkers are bored with Mystique...
...um and prolly with our conversation too :P
https://www.sau.com.au/forums/topic/37786-mystique/page/5/#findComment-802388
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
    • Hi guys,  I just replaced my pads with blue stuff and flushed fluid. The pedal and brakes feel fantastic but I'm getting very slight pedal stutter under any kind of braking. Not every time, maybe 1 in 10 and not under any heavy braking, mostly occurs as I'm reaching a stop. It feels like abs engaging but it's so fast, there and gone in under a second and no abs flash on the dash.  Any ideas what could be causing this?
    • How does dead head help with emissions? Is it being claimed for emissions because fuel in the tank isn't being heated up by being pumped around, hence should condense more? One part that is a negative about dead head is heating the fuel at the rail a lot more (IE heat soaking at traffic lights) and this causing lean outs on takeoff afterwards. If my thoughts above are correct, I wonder how different the tail pipe emissions become with the lean outs vs less fuel tank emissions into a charcoal canister
