My vacume hose on my Turbo Smart Eboost2 has a small split in it, Sucks because all i hear is a hissing noise (ssssssss) :(. does anyone know if its easy to change it yourself or know anyone that can change it for me?
*Note, would rather someone do it for me or atleast look over me so i dont f**k anything up.*
Cheers.
https://www.sau.com.au/forums/topic/377900-help/
hardest part will be feeding it through the firewall to the solenoid in the engine bay.
if you tape the new hose to the old hose and pull it through it will make your life 100% easier.
other than that, just connect both ends
https://www.sau.com.au/forums/topic/377900-help/#findComment-6026661
Be sure to put the hose in the right way around or the air will flow backwards. Check for the arrow on the hose.
I think that for those hoses you also need a left-handed screwdriver to tighten the clamps....
Edited by SatchiThaStagea
https://www.sau.com.au/forums/topic/377900-help/#findComment-6029189
No that's just for the hoses that run to the flux capacitor, there's no issue if you use a RHS screwdriver provided you stay under 88MPH.
I think your thinking bout the one that runs from the jar of sparks?
I meant the ones that are held up by skyhooks
https://www.sau.com.au/forums/topic/377900-help/#findComment-6029729
