Just what speed are you going when trying to shift down to first?
Really you shouldn't even be trying to shift into first if you are still moving
Exactly. First is for leaving the line. You shouldn't be changing into first until you are doing about 5kph.
That's what I do. When traffic is crawling like 5 km/h I change to first and it's hard it move the gearstick in there. I guess I can labour the engine or ride the clutch in second.
Edited by H4x
Even if the synchro on 1st is somehow worn out, a proper heel & toe rev match will allow you to change into 1st at any speed below redline. Of course doing so is only sensible at speeds that are low enough that it won't come on boost in 2nd instantly, but that's another matter.
Learn to drive.
Yeah, you really should stop before trying to put it in first- however if you get into the habit of double clutching you can make it easier on the synchros if you want to put the car in first and you're still moving- pop out the clutch in neutral and rev the engine (ideally to match road speed) before you engage first gear. I am assuming you are attempting to engage first at speeds that are too slow for 2nd gear to be useful.
edit- as above- you beat me to it, darn my slow typing.
Edited by doo doo
I want know what the problem is. Is it a worn synchro or something else? Remember it doesn't crunch while going into first.
Edit:
Also rev matching won't help, double clutching will if its a synchro.
Edited by H4x
mines a little bit sticky even 100% stationary .. usually when this happens i have to put it back in neutral, foot off the clutch, then try again and itll be fine - not really a big issue and doesnt bother me though
Sounds like you have the wrong oil in the box then or rooted oil. Mine is similar to your when its cold but when it warms up its better. My synchro's are a little worn. I would have thought rev matching it would help tho. It helps mine...
Hey, 180ks on the car and I highly doubt it's been changed before (engine oil looked like it had never been changed when I bought the car). I did think about changing the box oil, but there is a oil leak between the block and bellhousing, so I was sort of holding that off until the clutch f**ks out. About the rev matching, how does that help when the clutch is in? Shouldn't you put it in neutral (clutch out) and rev the engine to match your roadspeed then change to first?
I did say heel & toe rev match. That tells you everything about what I meant. Clutch pedal down, move gearstick out of gear, clutch pedal up and roll right foot so ball of foot stays on brake pedal (assuming you're doing it under brakes) and blip throttle with side of foot, clutch back down and move gearstick into 1st, clutch back up with right foot now either firmly pressed on brake (assuming doing it under braking and not wanting to take off just yet) or firmly pressed on accelarator (assuming you've timed your shift correctly and you are now ready to abuse the tyres in 1st).
If you're not doing it whilst braking you can just blip the throttle normally.
Guys need some driving lessons, double-de-clutching is just rev matching.
You don't even need the clutch once your revs are right.
Try an old Mack quad box, only use the clutch for initial take off, then rev match all the rest, no clutch.
Miss a gear and you'll break your wrist.
No synchro on those bad boys.
I didn't say double clutch, because double clutch doesn't actually mean anything (unless you're talking about various modern gearboxes with two clutches). The correct term that you ae thinking of is double de-clutch, but you really only do the classic old style double declutch action in old non-synchro truck gearboxes. When you double de-clutch in a car in a performance context, the action that you use is the heel and toe movement. Nearly everyone that I can think of that knows anything about driving cars knows what heel & toe is. They never say double clutch, but they definitely say heel'n'toe.
^ how do you double clutch?
I have been trying to do this while i drag race ford falcons and holden commodores around the streets like brian did in fast and furious (except he raced american muscle cars!)
i think if i learn to double clutch, i will win, because brian learned to drive and he almost beat vin diesel in the 4th movie with his r34 skyline
i also have a r34 skyline - so if i learn to duble clutch, i think i can beat all muscle cars.
especially since i upgraded my exhorst and put my body kit on.
I joke. I was actually gonna write that quote from fast/furious though Allan LOL
yeh mine does the same, hell even when trying to go from 3rd to second it sometimes doesnt want to slot in like it should (similiar to what it does going from 2nd to 1st at lower speeds).. synchros are knackered i believe, changed the oil months ago with no improvement.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
