Does anyone know where to get an Axis rear skirt and how much they are?
I am getting some work done on the front and while I am at it, I would like to stick one on my ARX and colour code the thing (whole car).
I have never used Import Monster or Yahoo or anything like that..... Is this the most likely source and is it difficult?
Cheers
https://www.sau.com.au/forums/topic/378224-axis-rear-skirt/
The easiest way is to just email jesse streeter and ask him to find it for you. Great service. pm me if you need his email.
Check ebay too, theres been heaps of panels on there lately.
https://www.sau.com.au/forums/topic/378224-axis-rear-skirt/#findComment-6031494
Here's one that needs a touch up and paint.
Import Monster link
Streeter link
Oh, and here is a silver Axis front bar in case you want to match the front with the rear
Import Monster link
Streeter link
Buy both, then paint what needs to be painted and you'll still be better off than buying them from Nissan.
Hell, you could probably get an exhaust with the money saved.
https://www.sau.com.au/forums/topic/378224-axis-rear-skirt/#findComment-6031926
Import Monster link
Streeter link
Import Monster link
Streeter link
Awesome, thanks for that! I will look at the rear. Insurance pays for the front I hope.
https://www.sau.com.au/forums/topic/378224-axis-rear-skirt/#findComment-6033235
So send it to Melbourne and get it couriered from there?
Otherwise if youre stuck ask Import Monster?
Hmmm, sounds like a plan.
Also I asked Jesse about combining multiple items to reduce costs but he said this isn't really an option....
You still looking at getting stuff?
https://www.sau.com.au/forums/topic/378224-axis-rear-skirt/#findComment-6034689
Reason being is that every single item shipped via container has to be listed and accounted for.
Shipped by air does not so Jesse or IM can chuck as much stuff in the one box as possible to reduce shipping costs on small items.
At least that is what I am told
Also, Import Monster's containers come to Melbourne as well.
https://www.sau.com.au/forums/topic/378224-axis-rear-skirt/#findComment-6035232
Import Monster link
Streeter link
Import Monster link
Streeter link
How did you find these? I have browsed and searched all sorts of key words and can't find these items independent of the using the links?
What am I doing wrong?
https://www.sau.com.au/forums/topic/378224-axis-rear-skirt/#findComment-6038185
Just a heads up. For container post IM might work out a tad cheaper. They charged me $125 for container shipping for the nismo front bar. Streeter charges $250.
IM's commission is quite high though...so get a quote from both. Not sure if I was lucky or IM's containers leave more frequently, but I bought two front bars, one with Streeter and one with IM. The IM one was won on 11/08/11 and a couple of weeks later it was in a container on its way over...
The one I bought via Streeter (19/07/11) is still sitting at a yard waiting to go in a container...>_<
Not that its his fault, but if you're going container shipping it might be better with IM as they have their own containers whereas Jesse relies on others (J-Imports - Melb, JDMimport - Bris)
Edited by ironpaw
https://www.sau.com.au/forums/topic/378224-axis-rear-skirt/#findComment-6038619
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
