Wrecking skyline R33 all parts for sale:
1. Apexi Power Fc good condition $1100
2. unknown brand half roll cage bolt in $400
3. Rb25. forged bottom end stage 3 tomei cams and adjustable cam gears standard intake manifold HKS low mount ball bearing turbo 2 months old and custom made manifold want to try to sell as set $4000
4. 3 inch turbo back exhaust no cat straight through pipe $ 400
5.Transmission 5 speed gearbox $400 perfect condition
6.brass button clutch only 5000 kms $800
7. diff and drive train ?? make an offer
8. bonnet no dents $150
9. drivers side guard $50
10. 10 spoke race wheels 60% tread left $500
11.nismo dash only 100,000 k on the clock great condition $650
12.all interior parts make an offer
13. front and rear seats no stains lie brand new $500
14. stock sway bars $150
15. blistein shocks and lowered springs $300
16. Front brake rotors and calipers $450
17. Rear brake rotors and calipers $250
18. sunroof working perfect $600
19. dash and passenger airbag $350
20. steering colum $150
21. Steering wheel and airbag $250
for any photos or information or if your looking for any other parts call or message me on 0405476412
https://www.sau.com.au/forums/topic/378552-wrecking-r33-skyline/
sorry should of mentioned its a series 2 but it has aftermarket front, rear bar and sideskirts sorry mate
and the location of the parts is penrith sydney...willing to ship if buyer organises shipping
Edited by mantra
cant load up photos but will email or sms them on request need parts gone asap
1. HKS gt rs ball bearing turbo 2 months old and custom made 2 inch manifold and turbo to cat exhaust $3500
3. Rb25. forged bottom end stage 3 tomei cams and adjustable cam gears standard intake manifold air con and all accessories $2000
Is that a manual Rb25det gearbox forsale..... if so ill take it....?
The intercooler kit is it return flow or normal style cheers PM me
Hey mate gearbox might be old waiting for deposit but not to sure bout the intercooler ur welcome to look at it and find out mate
thanks
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
