  • Replies 69
Pretty much what my number 6 looked like when it let go....
it had standard pistons running 285rwkw.
what generally causes the piston to break away like that... is it just cause they're weak? or is there other contributing factors?
Detonation/pinging. It smashes the ring lands off pistons, and gives the rod bearings a good hammering at the same time. A look at the piston crowns and rod bearings, and the crank rod journels may reveal more.
hmmm interesting thanks for the reply...
it was my number six cylinder and all the rest were fine
im assuming because that cylinder is at the back of the engine it gets alot hotter causing it to detonate/ping
Also just before i noticed the car blowing blue smoke i took the car on a long drive from sydney to Wagga,
the car was loaded up pretty heavy, id say it would have been carrying an extra 350-400 kg then it usually would.
could this cause the engine to detonate/ping due to the extra load?
Yes I have....although I think it was load, not boost. I spun a big end bearing shortly after. seriously.
I get the points. Wait until the big ends are checked.
f**ked bearings/clearances = low oil pressure under load.
A lot of things cause detonation. Perhaps it was running a tune on the razor edge of safety vs death. An especially cold day or a little blow by oil in the intake could have been all it would take to push it over the edge.
The blue smoke you saw most likely happened after the damage was done. The rod bearings will tell the rest of the story.
They can withstand 400rwkw if tuned correctly. The issue is heat and detonation. At those kind of power levels all you need is it to go slightly lean, or you be running it really hot and on the edge of detonation, hard corner and surge = lean, or putting it under load that it hasn't been tuned for and the tuner didn't richen/retard those cells making the motor detonate.
Basically down to tuning/fueling/cooling issue.
in that case i would be suspicious of the extra load the car was carrying on that long trip a week or two before it let go....
ive been informed that the PFC doesnt retard timing when knock levels become high,
so i guess what ever load the tuner puts the car on the dyno is what the tune is made for
cheers for the reply mate
A good tuner will tune the cells above what is being used extremely rich and retarded, much like what nissan did from the factory, hence the R&R feature everyone sooks about, at least their engines don't blow up though.
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
