Hey Guys,
Im currently looking to organise a small group purchase on the BHSS Paging Car alarm (BHSS-270A i Think.
This Alarm retails for Approx: $500 australian, however it is an imported alarm (Not avaliable in Australia)
Now I have been looking for a Alarm with a Pager for awhile, and there are not many on the market. Infact I could only find 2 other models which were: Boomerang and the Steel-Mate 888a (Another import Alarm)
I was orginally going to go with the Boomerang Alarm system, however at $1000 australian I felt it did not offer enough 'Bang for Buck'
Thats when I came accross the BHSS alarm, which my friend had Installed on his Skyline. and I have found it to contain almost the Same features as the Boomerang Alarm System has.
Now on to the good stuff - The alarm system consists of the following Features:
•Keyless entry without pressing the button of remote control
•Ignition auto-door lock/unlock
•Car driver paging
•Trunk release
•Personal system set-up on the remote control,silence/shock sensor can set-up
•Wide, illuminated remote control LCD screen
•Temporary lock for remote control buttons
•Automatic diagnostics of the system's status
•Battery low warning
•Built-in central power door lock relay
•Passive door lock
•Door open sensing
•Shock sensing
•Start disable in arming status (2 Point immobilizer)
•Auto-roaming
•Passive arming
•Remote control shock settings (remote control over cars shock sensor)
•Beep sounds and icon won't flashes on the LCD screen when the system is triggered
•LCD screen illumination when the system is triggered
•Emergency panic alarm
Engine start features:
•Remote engine start
•Cold weather start- will attempt to start 3 times, if first attempt failed a 2nd attempt will occur 1.5 later. If the engine does not start again a third and final attempt will occur 2 seconds later.
Please, If you have any Information or Questions to ask, Either drop me a Private message or leave them here and I'll be happy to find out the details for you.
For note, I am purchasing these alarms off a Supplier in Queensland and Im looking to place the Order Possibly within the Next 2 weeks.
1-4 units $450
5-8 units $375
10 units $355
If the Required Number of people is reached, the Alarm will cost $355. Please Note if your purchasing outside the South East Queensland Areas and Require postage, an additional Postage fee shall be required.
Regards,
Matt
https://www.sau.com.au/forums/topic/37891-bhss-pager-car-alarm-350/
Ok, Ive had a bit of mis-communication with the supplier (read: hes ****ed me around)
Im still in talks with him, but it appears the final price will be $355 if i can get 10 people
insstead of $350 if i can get 5 people.
As you can unserstand, im pretty pissed off with being screwed around
So just letting you know there are still slots open.
twoquick - your welcome to join
yotis - dont you alreaqdy have an alarm and that?
why only 10 units? im sure the guy wouldnt mind selling more then 10.
if a spot becomes available anyway ill take one, whats the name of the place cause even if I had to pay $450 for one it sounds like a good price, you can pm me if u like
  • 7 months later...
Hey Guys,
•Car driver paging
•Trunk release
•Passive door lock
•Door open sensing
•Shock sensing
•Auto-roaming
•Passive arming
1-4 units $450
5-8 units $375
10 units $355
Regards,
Matt
have a look at Mannix too mate :)
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...4504313150&rd=1
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
