As heading says,
- Sard/Denso 1000cc Injectors (195500-3650)
- Sard Fuel Rail to suit with fittings for -6
Have misplaced the mount for the fuel rail, but easy to make something up for yourself.
Just used for run-in period and now have been upgraded.
Will post.
$700
Reply here or PM me
See my other thread for T51r setup
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
