came across this great comparo of ethanol vs petrol
http://www.youtube.com/watch?v=x2BXuI52fOI
my local united is now stocking e85, so ill be keen to compare the ethanol content of united vs caltex with my zeitronix
Edited by domino_z
my sensor was reading E80 but there was still maybe 10-15litres of E70 Eflex in there - so it looks just like the old United E85 ie generally on the higher side of E85, like Martin said.
all the eflex should be out of the system now, so i'll fill again with United and see where it's at. Let you guys know :)
interestingly though, for the last 5-6 months, Caltex has been bang on E70, never moved when i checked. I wonder why United doesn't control the % as much?
  • 1 month later...
onto second full tank now, sensor flicking between E84 and E85, sensor was reading E83 on the way to the station - looks like it's not varying wildly like last time united was around :)
yep united e85 is the way to go - which store are you getting yours from daniel?
couple more updates. swapped my bootlid over to one with a third brake light, and had it ordered with a matte finish which i left unpainted on the under side
if anyone is interested in my old bootlid, shoot me a pm
also got my top racing dry cf mirrors back after getting painted - need to work out how to pop the glass out so i can unscrew the motor
love the bootlid, the subtle spoiler kick is really nice - i wanted to do something like that for my old GT-T but never got around to finishing it.
thought about leaving the mirrors dry cf to show off the quality?
I got my United from what i think is technically Braeside, not sure if that's how it's listed on their website, but i think that's the suburb. Near boundary rd/lower dandy rd intersection. It's closer than my closest Eflex too (springvale) so it works out well. Now if Fueltown just got back up and running, i'd only have one a few mins away :D
local to me was brunswick living in the cbd, but they've scraped it now
i have to drive out to balwyn, which is around 8km, not too bad, gets me out of the house on a boring week night. But i also have caltex in hawthorn and footscray which is a bit closer
re mirrors, i prefer subtle exposed matte cf. not painting the insides is a nice detail when using the mirrors from inside the car
Edited by domino_z
  • 4 weeks later...
guys united is going all out and ramping up the servo's now offering e85 in melb
united kingsway (next to merc) is the latest, perfect for me living in the cbd
http://www.unitedpet...cator/fuels/E85
Edited by domino_z
think it's time for me to take the next step
not really interested in a drag car so ruling out big turbos. what ideally im after is stock turbo like spool below 3000rpm for the daily drive duties, and abiltity to carry more boost towards redline for better in-gear acceleration
starting to do my research now on engine internals and turbos, though willall's spec v style porting seems to be the way to go - anyone here done the willall turbo mod?
Edited by domino_z
  • 1 month later...
domino - did you ever get around to looking at upgraded turbo's?
I'm curious to know from your investigations if running this upgrade on E85 can still get away with 1000cc injectors?
We are supposed to tune my car later this week on E85 for the first time but I only have ID1000's and am not sure with the extra supporting mods if they will be big enough now.
Martin would best advise whether my injectors are currently max'd (or close to it) on stock turbos - i doubt it though, keep in mind HKS went all the way to 800+hp with their 860cc injectors
I'm still on the fence with turbos - problem i'm having atm is traction, and i can't use all the power i have on my 21" street tyres. 2nd gear is pretty much useless in this cold weather, and 3rd through midrange will cause the car to snap out well past triple digits. I'm considering swapping out my yoko advans for ps2's but i really dont think that will help much
I'm convinced on the benefits of SD tuning vs MAF, so will be having Martin tune for SD at the least
Edited by domino_z
Yeah we are also switching to SD. I tried the upgraded AMS AFM's and they were an epic fail so will go with SD tuning moving forwards.
And I guess we'll just have to try the ID1000's and see.
you'll need pumps too, but im sure you've already upgraded those
is racepace looking after your car in Vic? i may be confusing with another member, but is yours the jdm black gtr with spec v turbos?
Edited by domino_z
Yeah Racepace are doing the car and yes its the black JDM with Spec V turbo's, pumps, cooler, pipes etc.
The car was making 440awkws on 98 with a MAF tune (stock MAF's maxed out in places with-in the tune range but the AMS ones caused a massive back-fire on lift-off and unfortunately I had the crash at Mt Baw Baw rally before we've had a chance to look at it again. Only got the car back last week).
So quite interested to see how it goes on E85 + SD this week. Going to PI this weekend for the real test.
Hey Snowy,
I have an SD tune in mine at the moment with the 3inch intakes and am getting a huge backfire on acceleration on 98 as well. Going back to the MAF tune until I can get the MAF delete loom here. Then back to the SD tune and see what happens.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
