Melb Auto Salon '04 - PICS Only Thread. **OPEN**
Hey all,
Finally got around to scanning (ah, the joys of film!) some of my photos and here's a few favourites. Heaps more to come.
As usual, high res versions will be here:
http://www.skylinesaustralia.com/photopost...all&ppuser=2652
-Greg.
  • Replies 73
Coz its black, and it was in low light. Hence shutter has to remain longer to get a proper pic of your car or it will come out too dark. If shutter is open and you even twitch your finger while holing a cam you'll get a blurry pic (hence the need for a tripod). Seeing as only greg had one and a decent camera, I'd expect him to have a good one of yours.
I didn't use a tripod for any shots, they were all handheld. I was using a slow, rear-curtain flash which exposes the picture for the ambient light and flashes the subject (at around 1/840th second) keeping the subject clear.
That and the camera weighs a few kilos so hand-held shake is lot less noticable.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
