Hi guys,
I am wanting to get a different BOV but i want the flutter sound valve not the typical whossshh. What are the names and models of any flutter sounding BOV's that you guys know of. And if any of you have one are you willing to swap for an HKS BOV?
your help is much appreciated,
Thanks
JL
https://www.sau.com.au/forums/topic/37919-bovs/
I never knew u could buy BOV's which make the flutter sound
ive got a factory bov with an fmic and i get the flutter....pretty sure its only the fmic which makes that noise
Or by removing something around your turbo so air hits it harder or against the wastegate ??? which creates the flutter...
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763682
shouldnt cause to much damage
thats same sort of principle for VLs when they wake on a cooler and get flutter
my turbo is still in good nick and thats running some high boost as well
but then again stock skyline turbos r made from pottery clay :-p so i wouldnt really risk it..
nick lets test it on urs :-)
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763750
Get a BOV, plumb it back, and get performance out of your car.
I think he's more concerned about the noise his car makes rather than the performance of the thing. :D
runnning no BOV hinders performance... u serious??? haha
Dead serious...... what are you laughing at?
:slap:
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763838
*sigh*
well from memory a BOV unless running high boost is not going to improve performance on anything... infact im pretty sure in one of my speed mags where they had a 4 page spread on them and what they do they are only designed to release pressure to extend the life of your turbo.
https://www.sau.com.au/forums/topic/37919-bovs/#findComment-763900
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
