mate, if you can:
stay away from mirrabooka, girrawheen, nangebub, in the north, stay away from forestville/field in the east, south = stay away from armadale and canningvale, but the west is good, if you got the cash; go to applecross, or como or around garden city shopping centre is nice :P it all comes down to price range (perth is like the dearest place to buy full stop)
Forget Lockridge.........cheap for a good reason as explained above. I had a house in Beldon for a few years, that place was OK, dunno about now though. Clowns all over the place these days. Good luck with the house hunting anyway.
Cheers GW
Fkn LOL @ telling someone considering Lockeridge, that armadale is dodgy :laugh:
I have been living on the armadale line, on and off, for over 20 years, and have never had a problem. Never been bailed up on the train stations, never even had a reason to call the cops for anything.
That's cause you're the one doing all the break and enters ;)
cheers for the info, yeah its hard to decide, it seems only now i realise how little i know about suburbs.
my price range is only round 300-400k, so nothing too spectacular
its funny coz when i ask my mates etc it seems everyone has something bad to say about everywhere! :P
well, there IS that.......
But yeah, every suburb has its own issues. Best tip I can give, is that if you find a place you like the look of, go back a few times, at different times of the day and night, and on different days of the week (such as pension day, about 7pm) You will soon see any warning signs.
Price will be inversley proportional to how dodgy an area it, more dodgy = cheaper :D
not always true we have afew areas down here full of CUBs = costs a fortune but feels like living in rockingham
Dalkeith is considered to be the best "Rich" man subrub amongest the Chinese family friends I know...
But take it with a grain of salt as it is they are the same people that think a BMW 318i/Merc C180 is the same as a 7 series or S-class... :whistling:
My parents bought a block of land in a subrub called Jindalee (way up north, freeway ends before reaching there) & it looks pretty decent with all new houses & I've being driving there a couple of times at night/evening & didn't see any little shitheads runing around like I see in my current subrub.
Edited by Mayuri Krab
note to self:
Territory Borders:
Dalkeith = Chinese
Beechborro = Vietnamese
Beckenham = Lebonese
ese is the word
so far no one has said anything bad about Ellenbrook which is good as thats probably what im leaning towards atm :)
I went over to the ellenbrook shopping centre opening (had some business there). I thought it was a really nice suburb, till I went back the next day to find a stolen/dumped car in the main carpark with light pole toppled over. I didn't believe the locals till I saw it for myself.
But I'm from the east, what would I know!
But as the other guys say - budget dictates location. Building is usually cheaper than buying established, but it takes time. Maybe the 'predicted' GFC will shake things up...
Yeah, I'd stay away from Lockridge or Balga/Westminster. Most suburbs have their good and bad, just need to try to pick the area of each suburb. I've heard lots of bad problems about Armadale, but lived there for 6 months and didn't have a single problem, only moved because I was working in Joondalup. Caught the train to and from work for about half of that time while I didn't have a license and didn't have a single problem. Have heard dodgy things about Bassendean too, but at least the street I live on is quiet, except for the occasional douchebag deciding they need to floor it out of the slow point outside my house.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
