Hi guys
Finally got around to installing a couple more of my interior trim pieces in my quest to improve the rather plain monotone dash and without having to spend big bucks on a full retrim
I've gone the gear surround and ac panel matte cf overlay from RSW, 2011 mfd surround, a custom red/black gearknob and alcantara main gauge lid by blackmans, and the final piece a matte cf wrapped main gauge trim by Revozport (same guys who made my dry carbon boot lid) and they did an amazing job matching the weave to my existing RSW pieces.
Today was d-day in removing the main gauge unit and although quite straight forward using the esm, still was nerve racking making sure i didn't damage any trim. Plastic trim remover tools help
I have removed and box'd up my rear subwoofer cover to be wrapped in matte cf and will call it a day after i get that back
Edited by domino_z
ill most likely come up for a day trip
next step now is replacing my oem centre console trim - its full of chips and scratches after 1 yr
fingers crossed it's not ott expensive
ill try matte clear wrapping it
Edited by domino_z
i didn't do the carbon wrap, it was done by Revozport in Hong Kong - i definitely recommend them if anyone wants trim wrapped. You can choose gloss finish or a different weave if you prefer
i really don't know how they cut the edges so cleanly without distorting the weave as it's not folded on the underside
Edited by domino_z
i sent my parts to them - with this particular part i bought a spare as i couldnt be off the road for over 1 month waiting for it to come back
i have both of my oem pieces available if anyone wants to do same/similar
Edited by domino_z
  • 4 weeks later...
bump
i have zero interest in horses, but ill happily take the day off
spent ~3 hours sitting in my boot with some scissors and a roller - took the time to ensure very little overlap bw sheets to reduce the weight and product/cost
in total i have dynamat'd under the rear seats and now the full boot floor and it's done wonders for reducing the amount of exhaust boom, road noises and random r35 drivetrain creeks n groans
imo the boot had a much bigger effect then under the seats, so if anyone wants to give this a shot, start there
the die hards will snicker at the weight gain, and fair enough if you're an unmasked stig. Ive used roughly 6kg so far, but imo well worth the weight penalty (which ive compensated with a carbon trunk, ti exhaust, forged wheels etc anyway)
Edited by domino_z
yeh i cleaned up my photobucket by sorting all my pics into folders and its broken links everywhere
i bought the bulk pack off US ebay - even with the shipping, its still the cheapest option
in hindsight though i wouldnt have ordered so much - i used less than a 1/3 of it
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
