Just trying to understand how much am I losing, gaining, if I go with ATTKD instead of DBA 5000's - my original rotors are warped, and I might as well go the 2-piece route.
ATTKD 2-piece ones are $499
(+shipping) on justjap site, presume for a set, and DBA's are quite a few $ more.
Are DBA 5000's worth the extra money.
Is it hard to find replacement parts for ATTKD's? DBA replacement parts are fairly easy to find.
Any feedback would be great.
Cheers
https://www.sau.com.au/forums/topic/379506-attkd-vs-dba5000/
I'd be grabbing the ATTKD over the 5000's. Something to think about is the new DBA4000 design, iirc they will be around the same price as the ATTKD and can't see them being any better.
So I'd get the ATTKD.
I'm using the ATTKD / KSPORT / G4 / D2 330mm rotor
What are you using the car for??
If it's predominately a street driven car go with an ordinary single piece rotor. Under your foot your not going to notice any difference from a base model RDA to a 5000 series DBA.
Well, I'm basically using it to fill the empty space in the garage, but I do a track day or two. Hoping to do all the SAU-Vic rounds next year, so could see some use for the 5000's, otherwise I'd go for the 4000's.
Thanks for the advice John, considering the pace you do guess those ATTKD's are not bad at all then!!!
I recently converted my front end brakes to ATTKD 8 spots & 356mm rotors & can't fault them what so ever . Great on the road , great on the track with no break fade what so ever . For the price i think they are great value for money :)
If you do end up deciding to just go the 4000 series, we've got 9 pairs of front slotted to suit in stock that we're doing on special at the moment, $184.80 per rotor.
need 18's for that setup - otherwise I could run them in the future.
I have 19's on mine , so i have no problems with clearance . Your right though 18 are the minimum with the 356mm rotors :) I have the Attkd 8 spots up front , with standard 2 spots at rear with Dba t slot rotors & project mu pads. Also got braided lines all way round , cusco master cylinder stopper & Motul Rbf 600 brake fluid . This setup is fantastic & have no brake issues what so ever !
Well, I ended up getting a set of ATTKD's 2 piece rotors, DBA mucked me around a bit, took more then 3 weeks since I put an order in and they still couldn't tell me if and when I'll receive them so I cancelled the order...................but funny thing happened with my original rotors - they don't feel warped any more, even when I brake really hard they feel smooth just like before. hmmm, funny that ey, so I decided to leave them on the car for a while and I'll swap to those ATTKD's later - its not bad having a spare set of rotors on the bench.
You guys reckon they'll just warp as soon as they get hot again or they may be ok for a while longer?
Damn, I didn't knew about these... let say, I start learning how to lap next year, would the DBA 4000 still be fine or should I go ATTK right away?
Anyone tried the AMS rotor?
http://forums.gtrcanada.com/ams-absolute-motor-specialties-inc/42748-ams-max-slot-16-r32-2-pc-front-rotors-intro-sale-%24399.html
http://forums.gtrcan...ale-%24399.html
I would keep the original rotors on, until they crack or warp, and just fit the car with good brake pads, and really good brake fluids. Your old discs are probably very good, they would have gone through the heat cycle many times and will be better then some brand single piece disc.
I used original rotors with DS2500 and RBF600.
was also looking at the comparison as i hae the DBA5000's on atm and considered the difference against the ATTKD branded ones. have spoken to Justjap and theyve told me its technically same as the D2/k-sport/taiwanese-made gear, just with a japanese company branding on it with the workshop's consent.
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
