another way to deal with this ( GTR in RWD ) is buy the "Full Race" 4WD controller, it has manual and auto modes, and in manual at the turn of a knob, all the way one way is max 4WD and the other way is complete 2WD=0 transfer case pressure.. also replaces the old Attessa computer and old G-Sensor, with much faster computer and better G-sensor, sounds perfect for track and strip... I got one coming (-;
ps, doesn't matter if R32,R33 or R34, makes them exactly the same...
ive wated to grab on of these aswell. looks to be a good bang for buck ATTESA upgrade.
did you get the ETS- PRO one? im assuming thats there product name, and not the model of ATTESSA it is suited to? a little confussing
Q: Does ETS-PRO work on vehicles with Active Rear Differentials:
A: We have not tested compatibility with Active Rear Differentials at this time. Instead, we recommend using the ETS-Pro with a clutch pack type differential such as stock GTR 2 way (reshimmed to NISMO spec plate:disc:plate:disc is highly recommended and free). Most high quality aftermarket units with a smooth lock like Carbonetic, ATS, OS Giken (soft lock) or Nismo may also work well. The key for a 4wd car like this is a smooth locking diff that is not overy aggressive, but does not slip open either.
Also a little unsure on it working with the ABS as per below
Q: The OEM system interfaces to the ABS system, why don’t you have any interface to the ABS system?
A: The ABS sensors are used on the OEM system to provide a method to increase the engine braking force and also open the diff in emergency braking situations. The ETS-PRO system comes with a "braking mode" program which has an emergency braking routine built into the braking program, allowing the diff to go totally open - so the brakes at each wheel can act independently in relation to the ABS in an emergency. We have weighed the option allowing customers to cut and splice into the ABS system in order to integrate the controller into it, and decided that it was high risk with no benefit.
Let me know how yours goes once its installed, Dosnet look they any of them replace the attessa ECU though?
have you compared this full rave one, To say ruzic, or tarzans?
yeah the ETS-Pro..
I got rid of the A-LSD, great upgrade, and depending how you wire it up ( there are 2 options) it does completely replace the Attessa computer for 4WD control, except as pointed out above, not for ABS or A-LSD,. so I'm going to hard wire the ETS-Pro for the 4WD and leave the standard Attessa computer to do ABS.
Will report how it compares to the Ruzic I just took out, which was great for the track, and the new GPS one looks even better. But I like the sound of the Full Race one, whereas the Ruzic is map based the Full Race has map based and manual, in manual you have complete control, from max 4WD to complete RWD, could be handy for tyre warming at the drags, dynoing, drifting, etc
  • 5 months later...
Sorry for the old thread dig, is the attesa bleed wire removal + brake pedal pump method confirmed safe?
As per my service manual, and the fact that when I put it into rwd, I look on the torque transfer gauge and confirm no torque is being transferred.
Besides, The MANUAL says that you do this when towing the car with 2 wheels in the air.
Yeah mate it's perfectly fine, I get my car tuned on a 2wd dyno and the above is all I do! I actually have it hooked up on a switch to make things easier!
  • 3 weeks later...
I seem to be having some trouble getting it to RWD mode.
It's a hit or miss when I try to do it, sometimes it works and sometimes the 4WD light stays on.
I think it might be the turbo timer function on my alarm that's causing the issue...
I turn the key to "on" then I see the 4WD light turn off then I start pressing the break while starting the car and I keep pressing the break pedel until I see the 4WD light flashing.
This method only works for me sometimes, am I doing something wrong?
When i tried the RWD mode, my 4WD light was constantly flashing the whole time, there was no torque going to the front according to the factory gauge...and you could feel it. I presume its normal for it to constantly flash.
What i did was.
1. Disconnect the plug
2. Start the car
3. Press brake pedal till the 4WD light starts flashing
4. Drive
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
