looking at building a strong RB chasing revs not over all power or response
what path do people think i should go down
parts/motors i got
rb25de neo x1
rb25det x3
rb20det suit rebuild x2
turbo t67 10cm hight mont
nistune and all the bolt ons
full work shop with equipment with ok mechanical experience, hands on yes theory no haha
help be appreciated thanks matt
  • Replies 45
I'm guessing cause it sounds cool.
Rb 20 crank in 25 block with gtr or stronger rods and custom forgies would rev hard and hold together.
Makes the gears abit longer and i love limeter
Normal 300kw 25 is getting abit boring
Thinking of working neo24 for its soild head with 20 crank and rods, low comp, porting
Not sure what cams valve springs to use or type hmmm
Ye there is some serious investment that needs to go into the head.
Just a set of springs really isn't going to cut it for extended 9000rpm+
sounds good. some 290 degree cams maybe?
Well 290 degree cams give you 1000rpm response over any other choice according to some around here, so they should be the first items purchased!
espesially is they have JUN or HKS stamped on them..
No other 290deg cams will do it though
Hahaha.... But seriously you want revs and you don't care about power or response... Buy a Honda with vtec yo, or for even more fun, go an give yourself a tax audit.
You'd be mad to put in anything less than 320 degree
Or use the money you will need to spend on it rev to 9k for any extended period without lunching itself on 5 stock motors with boltons like most skidders do.
Lunch a motor, swap in a new one, simple.
Do that.
The most insane RB track car I've ever heard, as well as a large amount of guys from the drifting in melbourne was powered by a stock RB25.
Of course if it had 290 degree cams and a smaller stroke crank with custom rods and pistons it would've been better
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
