Hi All,
I'm quite new to this scene and now in the market for a R34 GTR. I've found the perfect GTR but unfortunately it's not a V-Spec...
Due to this vehicle being highly modified, the only thing left that matters is it has the standard mechanical LSD.
Should I steer away from this particular R34 GTR due to this fact?
FYI - It has approximately 700hp@engine and 550awhp.
Would like some opinions if it matters, if having the active LSD makes handling better, what the advantages/disadvantages are, etc..
Many thanks!
Rob.
https://www.sau.com.au/forums/topic/379872-r34-gtr-or-r34-gtr-vspec/
Having standard mechanical LSD already in the car makes it easier to maintain over active LSD(extra fluids, sensors etc)
If you really want extra grip, whack in 1.5 or 2 way diff - if having non V-Spec means installation is as simple as taking the centre diff out and swap over with aftermarket item - with A-LSD you'll need to find non A-LSD diff cover anyway.
So you shouldn't walk away from this car just cause of LSD as you have said it's modified (non V-Spec and V-Spec makes no difference whilst modified really).
All the best with the purchase, hope it's all good with the car.
Count is correct. stock vs stock. I would take the V-spec.
Modified cars are different. If the modified car suits you then purchase it. You'll more likely save money that way.
You can always sell the modified parts and revert it to stock or even purchase the V spec parts and have a sort of stock GTR with V spec upgrades, lol.
Thanks for the advice fellas.
I was under the impression with active LSD it has the ability to transfer power to the back wheels/front wheels from side to side as opposed to the mechanical LSD which can transfer from back to front only.
Any other advice based on this comment? :)
Cheers again!
Cheers again!
What is an A-LSD?
The diff is controlled via an ECU in the boot next to the HICAS ECU.
The ECU triggers a hydraulic pump that pumps a hydraulic fluid into the diff to lock it up when required.
It does this by observing the behaviour of the wheels and when it detects that one wheel has broken traction it will send power to the other wheel to compensate and keep maximum traction.
So in theory it is ment to behave like an open wheeled diff all the time and behave like a locked diff when needed.
In theory this is great however it doesn't always go according to plan.
The problem is the response time.
When a wheel starts losing traction the diff should instantly recognise it and go into action instantly without you even noticing. This would give perfect traction. The thing is, this doesn't happen.
The single wheel will break loose and in certain situations the diff will take ages to send power to the other wheel - sometimes not at all.
This causes very unpredictable "tank slaps" (Speed Wobble) when trying to go straight or when trying to slide.
- http://www.skylinesa...sd-information/
This might have been the case for the R33 GTR and Nissan might have improved it with the R34 GTR or could have stayed the same.
The theory still stands but in reality, it's different story.
I own a non V-Spec 34 with 340awkw (no idea what that equates to in hp), and the extreme amount of traction actually makes it a lil boring... Wait till you push it a lil and you will find how grippy these mofo's are. The helical diff in the non V-Spec is actually a huge improvement over the viscous units, they promote better traction and keep the rear a lot straighter whilst wheelspinning. I had mine in rwd mode for a couple of weeks after a dyno run, even with 275's you really begin to appreciate what the 4wd system does
I have a later model (01-02), which means that i get the sexy black interior, better coloured brush aluminium console, alloy pedals, and white dials. The 2nd gen R34 GTR is definitely preferable to the 1st (arguably the 1st gen vspec too). You will eventually seek your own stiffer suspension, bigger rear brakes, and diffusers that you miss out on. VSpec II's are still very expensive in Aus.
455rwhp you mean. :merli:
Not sure if the R34 is Vspec is the same - but i know it's a problem on the R33 Vspec.
What i mean by that is you cannot rebuild the A-LSD easily.
I need a rear LSD for my R33 Vspec as the A-LSD is shagged/playing up, from what I've found out i need basically a R33 GTR NON-Vspec housing and then put the Nismo diff (1.5) centre into that as the shafts or something is a different size between the A-LSD and LSD versions.
Not saying A-LSD is bad, it's taken a hiding in my car without a doubt. It's just a problem when it needs replacement.
So if the R34 is the same as the R33, then this will be a problem SHOULD the A-LSD fail. Otherwise it might well be fine for 5 years :)
I've owned both ...
* Non V-Spec R34 GT-R and a...
* V-Spec II R34 GT-R
...Rob.
And I wouldn't be put off one bit by the mechanical LSD.
Here we are - and currently F/S...
http://www.skylinesaustralia.com/forums/topic/379812-matt-and-terrys-black-r34-gt-r-for-sale/
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
