20,000Km Overdue Service On A Gtr- What Should I Do? Engine Flush?
Not changing the oil for that ammount of time is bad, but it's even worse when there is a turbocharger or 2 involved, it's quite common oil seals (rear main being one of them) have deteriorated and all that is holding those seals together is the sludge from the old oil.
If you do the timing belt, do the whole 100,000km service (belt, tensioner + idler pulley, both cam seals and the crank seal, water pump).
Since the previous owner didn't GAF, I think these 2 are important: brake and clutch fluid. While these should be done for peace of mind: front and rear diff, transfer case and gearbox too if it's hard to shift gears or crunches gears.
As for oil go with something very detergent heavy, it might even be worth getting some cheap oil in the correct weight (10w40) and using it to flush out the crap before putting a good oil in.
It's very lucky the engine hasn't spun a bearing actually.
i have bought a GTR and the last owner says it hasnt been sericed in the last 20,000kms.
why on earth would you do that? unless it was extremely cheap..
id get it to a mechanic asap - oils / fluids etc the list goes on and on
I'd be going the other way with the oil.
Get a cheap 10w40 mineral oil, and change it every weekend for 2 weeks. While running the mineral oil don't drive the car even remotely hard. Just run it up to temp gently and keep the revs below 4500. Especially dont flog it when its cold. The idea is you want to filter as much crap out of the oil system as you can, not have it bypass the filter and get to your bearings. Higher revs mean high oil pressure which results in some oil bypassing the filter.
After your 2nd quick change, then fill it with royal purple/motul or some other high quality synthetic.
Everything else you change and do will be determined by the age of the car, its level of tune and how many k's are on the odometer. Timing belts are a 100,000k item as are the tensioners. It would make sense to change the diffs, gearbox, transfer case, steering fluids and coolant just so you can start a logbook for the car's servicing. Then do the next service of these area's at 1/2 the due km's.
And in the meantime fingers crossed that nothing has been damaged by the neglect.
Agreed with GTRNUR, dont flush it with an actual engine flush, (i have seen those things loosen up too much stuff and actually damage the engine) use the likes of gtx and do regular filter and oil changes i went anal and did 2 changes in 300 kms so clocked 100km after the first one, dropped it then did 200kms dropped it and kept doing 200km cycles untill it started to keep it's color took about 4 all up, i also split the filters to see is any crap came through and there was none, once i was happy i put in 300v, and change religouslty every 3500km funny thing is that the oil now keeps it nice clean colour for some time before going crappy. I would'nt stress too much about it in that oil quality these days is pretty good to the extent that some manufacturers are recommending 15k intervals on turbo charged cars. but thats no reason to sit on it . might even pay to take the rockers covers off 20 min job and have a look to see if there are any chips of shit built up in there, that is always a good indicator to the rest of the insides.
yes a r32 GTR for $5000 i think its cheap :)
ok so im going to change the oil with cheap 10w40 mineral oil but how many kms should i do before i change it again with either the same cheap oil or good royal purple?
thanks soo much for all your help!!
$5K gtr??? :cheers:
nice work man!
follow the steps that GTRNUR posted..
if it's a daily, change oil and filter this weekend, use it next week, drop the oil and filter that weekend and repeat for one more week.
then put good oil of your choice.
If not a daily, then replaice oil and filter, then put say 200km through it while driving as suggested above.. and drop it and repeat.
most of these cars weren't serviced properly in Japan anyway..
and you got it at a price where you could afford to go get an R34 GTR motor put in for like an extra $5-7K and still be in front.
5k gtr..... basic oil change not done in 20k..... no doubt every fluid will need doing sounds poorly maintained.... no doubt other issues will come up too....
Edited by rgr34
I'd suggest taking small steps with the car and don't buy anything expensive for it. For example: No synthetic oils.
You have a lot to establish before you go sinking any money into it. If you jump in with both feet trying to restore it to its former glory you could end up with a bottomless money pit very quickly. GTR's can be bottomless pits when they are in good condition, so imagine how bad a neglected one could be.
I'd suggest doing a hot compression test after you do the first oil change. This will give you some idea as to the health of the engine.
Oil pressure when its been running and is over 80 degrees will give you an idea of the bottom end condition. If it still drives ok, then drive it for the first week as is. Only once its proven itself a little would I then suggest changing the diff, gearbox, steering, transfer case and cooling system fluids.
I you jump in too quickly you might just be throwing money away on consumables you will be draining again when you start replacing the broken parts. If things start going wrong, and also if the shell is full of rust it would be worth considering wrecking the car and selling off the components. You will end up making your money back and then some.
Then go looking for another bargin.
id pretty well go with this but id change it 2k or so after you do the oil change with good oil... never hurts to put a fresh filter and oil through it
will a 15w40 mineral be ok??
Yes that will be fine. The main thing you are trying to acomplish is getting the built up garbage out of the engine.
So the pre-requisits to do this are:
No expensive oils unless you happen to own an oil field...
Use a new filter
Change every weekend or 200km as has been suggested for 2 cycles before switching back to synthetic
Dont rev it past 4500, and especially when cold keep the revs low.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
