  • Replies 91
Dont rub it in man. Madden and i hit up cowes looking for one....couldnt find one. Tho you have just reminded me, looking for one tomorrow!
Everyone needs the dodgy $20 billabong straw hat :D
I think i got mine from Shepp a few years back?
John, Chris dont worry i found one for you just like Ash's : straw hat
BTW Chris congrates on the 66.91. I've been kicking myself over where i could have found 1.3s on that last lap......hold it flat over the finish line maybe :woot:
lol :D
Did you have the semi's on still in the arvo after i left?
Spewing i went home early with a 67.2 - getting close to the 66 marker which seems to be "the spot" for street tyres.
lol :D
hmm, no after I realised the semis put me into 'modified' class i frantically put the ku36's back on, missed one session doing this and then had one final lap to try and beat Chris's 66. Turns out even my best semis time wasnt good enough regardless and doubt i could have got there even if i had stayed on the KU's . Seems i have been watching too much Mark Webber and his tyre strategies are rubbing off on me!
still it was great a great tussle with Chris on the day an i enjoyed the competition. theres always next year.....
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
